Old 11-24-2002, 12:37 PM
grasshopper grasshopper is offline
IDIOT needs help installing first autometer gauge, hurry b4 i electrocute myself
ok, these autometer instructions that came with my gauges are all the same, and they SUCK...MISSION IMPOSSIBLE: Install 2-5/8" Electrical Water temperature gauge into a 1990 mustang. I've looked thru all these instructions and it seems i need some 18gauge twin conductor wiring? my other confusion involves how i'm instructed to wire the wire from the GND (ground) terminal on back of gauge to a good engine ground near sender...okay...where's the engine ground and where does the sender go in the first place? THEN there's the wire from the back of the gauge thats supposed to go to the ignition switch, WHERE IS THAT? AAAAND I have to take one wire from the light (pos or neg?) to either the dash lighting or other 12V source (like what, and what dash lighting, i hear i cant stick it in the ciggy lighter cuase it'll always be on) I'm so lost its funny( not to me, sad rather) any help would..well, help.
Old 11-24-2002, 01:18 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
what state are you in?
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 11-24-2002, 08:28 PM
i'm in the carolina's, mainly south but north from time to time...or did you mean state as in state of insanity! cuz yeah, thats where i am
Old 11-24-2002, 10:15 PM
I figured that maybe if someone in your area was bored, he could give you a hand. Sounds like you need it.
think "speaker wire." Preferably something so that you can tell which conductor is which (striped insulator, etc)
any convenient piece of exposed metal on the engine (preferably a small bolt)
Somewhere on the block or head, there is probably a threaded hole with a sending unit already in it. One end of the s/u is submerged in coolant, and the other end is exposed to the air...
ignition switch, WHERE IS THAT? um, it's the thing your key goes in. I think what you're looking for, though, is an open plug on the fuse box that becomes "live" when the ign sw is turned on. Use a test light or wiring diagram to find one.
one wire from the light (pos or neg?) to either the dash lighting or other 12V source it'll almost certainly be +.
what dash lighting the little lights that let you see the speedo at night, for example. Another wire that you can find using a wiring diagram or (with some effort) a test light.
Old 11-25-2002, 09:54 AM
thanks again for the patience, i'll let you know if i live thru it or not, right now i'm waiting on the exhaust housing to be fitted with studs...
Need help with tachometer install! AHHKILLA Eclipse 2000+ 0 05-03-2009 10:04 PM
need help installing mechanical oil pressure gauge gsxeclipse97 Off-Topic 6 01-31-2005 11:39 PM
Need Help Installing Air/fuel Ratio Gauge 5thGenAccord Accord/TSX/Accord Hybrid 0 11-06-2004 08:40 PM
need help installing mechanical oil pressure gauge 99eclipsegst Off-Topic 3 09-06-2004 05:01 AM
IDIOT BOY NEEDS help with first autometer install. grasshopper Mustang Talk 2 11-28-2002 03:33 PM
