Go Back   Automotive Forums Car Chat > Land Rover > Discovery | LR3 | LR4
Old 01-13-2004, 05:02 PM
bronwyn! bronwyn! is offline
Unhappy How do I fix these codes?
I have three active OBD II codes for my "99" Disco II. They are P0171, P0174, and P0734. The last one says Gear 4 Ratio. What does this mean? What needs done? Help...
Jason
Old 01-14-2004, 09:26 PM
I have found out that the P0734 code may have no real value to me. I still am not sure about the others...
Jason
Old 07-24-2004, 02:06 PM
clamb702 clamb702 is offline
those codes are for a mass air flow sensor hope it helps
Old 09-21-2004, 08:31 AM
RedRhinoProducts RedRhinoProducts is offline
Send a message via AIM to RedRhinoProducts
Re: How do I fix these codes?
I would pull power from the ECU to reset and try swapping with a known good MASS AIR. Drive the truck around the block, make sure to get through your gears under a load [heavy on the skinny.] The engine is running rich so I would also have a look at your o2 sensors. Check your code read out and see what you have.
Here is a full list of codes: http://www.disco2.com/tech/v8ems/faultcodes.phtml
Also, checkout www.get-rhino.com we need the exposure.
Old 09-22-2004, 01:39 PM
Cbass94's Avatar
Cbass94 Cbass94 is offline
Send a message via MSN to Cbass94
RedRhino, That's a great site of all the codes, now I don't have to look them up in the manual!! I agree about the O2 sensors, since it's a 99, the O2 sensors could be bad, especially if the car has been running rich for a while. The O2 sensors start to fade very quickly when the engine is running rich.
Old 09-22-2004, 02:12 PM
Just doin my portion...
Check out www.get-rhino.com.
Old 12-07-2004, 08:19 PM
Spin1now Spin1now is offline
Codes:
Hi ...Ive had many codes in the past.. even ones that tell me o2 sensors + mass air flow.....It ended up being a stuck thermostat after all the $$$ and headache....
How to fix a "p1694" code????? 99XXXJ Cherokee 5 04-17-2009 08:16 AM
how to fix engine code 4 mango1 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 12-13-2006 12:20 PM
How to fix error code backyardmechanic F Series 1 01-03-2006 05:17 PM
how much would it cost to fix these? chunkmonkey General 3 09-15-2003 08:52 PM
