Old 01-13-2004, 05:36 PM
killinfoo666 killinfoo666 is offline
Question 1991 3.4l grand prix
when pressing the gas my car bucks, it accelerates when on the gas then when still holding it in the same position it wants to idle then it goes back to accelerating. it does it repeatedly as long as you are on the gas. I replaced the harness to the tps and the tps itself.
if the car is in park and I accelerate it does not do it and it does not do it if I powerbrake it. it does it at all throttle positions except for around about 0-5% throttle.
would the egr cause this kind of problem??
Old 01-13-2004, 06:59 PM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: 1991 3.4l grand prix
That is hesitation. Remeber that when idling the car is not doing any force just reving the engine. When the car is under load then a faulty/clogged intake system air/gas could cause this kind of behaviour. Did you checked the fuel filter and fuel presure at the injectors?
Old 01-13-2004, 07:14 PM
that was the next thing that I was going to check.
btw when I started the car cold then turned it off after a min I could hear the fuel pump still running after I had gotten out.
Old 01-13-2004, 07:22 PM
kilroypr's Avatar
That is normal, but not for a extended period of time tought...
Old 01-13-2004, 10:32 PM
Smile
Thanks for the help.
1990 Grand prix le problem Erik23512 Grand Prix 1 11-05-2010 01:14 PM
1997 grand prix anti-theft system components Konstantin Grand Prix 8 10-13-2010 11:20 AM
1996 Monte Carlo Z34/ Cutlass Supreme 3.4L Idle Learn Procedure 96cutlass3.4 Monte Carlo 0 06-17-2010 11:43 PM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 09:57 AM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 04:27 PM
