Old 01-13-2004, 01:58 PM
Bungee's Avatar
Bungee Bungee is offline
Twin battery setup
Anyone know how to create a twin battery setup for a 2000 Silverado? Ideally, both batteries would be charged simultaneously thru the charging system, and the user would be able to easily switch between batteries at will.
I plan to do some off-roading with my Silverado 4x4, and it would be a nice backup power source to start the truck in case the primary battery craps out, or if accessories need juice.
I don't know alot about electrical work (but I do have an electrical tester), so a layman's explanation would be greatly appreciated.
Old 01-15-2004, 04:43 PM
Bungee's Avatar
bump
Old 01-23-2004, 02:06 PM
Bungee's Avatar
Bump
Old 01-23-2004, 02:13 PM
Phix_06 Phix_06 is offline
Re: Twin battery setup
Tell me how to Bump the system so that I could run it also
Old 01-23-2004, 07:35 PM
NWChevyGuy's Avatar
NWChevyGuy NWChevyGuy is offline
I'm gonna do the same thing. (for my stereo amps) I'm gonna get a stock Chevy Aux. Batterry tray that goes behind the radiator overflow. Then I'm gonna put in an Optima Yellow-top Deep Cycle. I'm gonna run one thick power line down to the starter with a battery switch in the line so its not always connected. (so I can switch the 2nd battery on to start the truck when the primary dies). Gonna run a thick line off the negative side to a good ground. (engine block probably) Then I'm gonna run a power wire over to the Alternator with a battery isolator in the line, so no current can be robbed from the primary to run the stereo, and also so power wont be taken from the aux. to makeup for a low primary.
So there will be 3 wires hooked to the aux battery.
I'm kinda rambling, so if this didn't make sense, let me know.
Old 01-23-2004, 08:13 PM
Bronco2 Bronco2 is offline
Visit a marine site/shop.Many larger boats have duel batts. with a isolator switch . This will let you do "bat 1" "bat2" "both" or "off". Using this setup will need no extra starter connections.
Looking for twin turbo setup VR43000GT 3000GT/Stealth 1 12-26-2005 09:09 PM
1985 Twin turbo setup 300zx_racer 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 2 05-31-2004 12:23 PM
Help looking for twin turbo setup lonny24 Camaro Discussions 7 03-07-2004 10:44 PM
Twin Turbo Setup Question Jedi276 Mustang Talk 14 01-30-2004 01:16 AM
wierd Q about a twin turbo setup raven_240 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 17 01-16-2004 07:00 PM
