Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-13-2004, 12:57 PM
heathershonda heathershonda is offline
Send a message via Yahoo to heathershonda
Question Basic tune up on 2000 Camry
I know this is a dumb question, but I just wanna make sure. What all is done to a 2000 Camry during a basic tune up ???
Old 01-13-2004, 03:50 PM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
Re: Basic tune up on 2000 Camry
A Basic tune up would consist of the following:
-Clean, inspect and test battery.
-Check all engine related fluids.
-Check and adjust all the drivebelts.
-Inspect the spark plug wires.
-Check the air filter.
-Check the cooling system.
-Check all underhood hoses.
Hopefully that should help, and if you want information on what needs to be done in a major tune-up, let me know.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 01-14-2004, 08:47 AM
Yeah, what's in a major tune up...is that when you replace the dist. cap and all that?
Old 01-14-2004, 07:02 PM
What you must do in a major tune-up is all the stuff that I listed before, plus the following :
-Replace the spark plugs and wires - coil pack and distributor if needed.
-Test the charging system
-Check the fuel system
-Replace the fuel filter
-Replace the air filter
That's pretty much it. Also, if you hadn't yet, you'll probably want to change your belts as well, the gen 4 belts seem to age rather quickly.
Old 01-15-2004, 08:54 AM
Cool, thanks alot
Old 01-18-2004, 03:04 PM
No problem, if you ever need any help with your Camry, let me know, and I will try my best to help you with it.
Old 02-05-2005, 11:11 PM
Night Speed Night Speed is offline
Re: Re: Basic tune up on 2000 Camry
hi can you help me?
i just installed TRD lowering springs and KYB shocks. and i noticed that when i turn on my engine i didn't see the ABS light on. usually when i turn on i can see the ABS light on then off. i checked the ABS is connect. so is that mean my ABS broke?
thanks^^
Old 02-06-2005, 12:06 AM
Maybe the bulb burned out...
Old 02-06-2005, 02:47 AM
oh... thanks^^
Old 02-06-2005, 02:49 AM
That would probably be the first thing I would check out...especially since you said it don't come on at all...all of the lights are supposed to come on when you turn the ignition over, to test the whole system..so if the ABS was "broken" in any way, the light would still come on when the key was turned over, and would stay illuminated throughout driving to let you know that there is a problem.
Old 02-06-2005, 09:14 PM
thanks
Old 02-07-2005, 05:23 AM
You're quite welcome...anything you need, let me know.
2000 Toyota Camry Rebuilt Transmission Computer Problem gujuchokra Camry/Camry Hybrid/Vista 5 08-20-2009 08:45 PM
Basic tune up Explorerman Explorer | Explorer Sport Trac 2 03-20-2005 09:21 AM
Basic Tune-Up Time, Need Advice. hondaokie Accord/TSX/Accord Hybrid 2 11-19-2004 06:08 PM
basic tuning question theshadow Nissan 350Z/370Z | Infiniti G35/G37 Coupe 11 08-03-2004 07:52 PM
basic tune up help taps65 3000GT/Stealth 3 12-17-2003 09:58 AM
