Old 01-13-2004, 10:57 AM
skier2u2 skier2u2 is offline
Manual trans removal on 91 2 wheel drive
The hydraulic throw-out bearing in this vehicle is failing. I am looking to replace the clutch components without dropping the cross member and dropping the trans completely out of the way.
After unbolting everything I can move the trans a couple of inches back but it seems to be stuck and won't go back any further even though there seems to be plenty of room all around. Am I missing something?
Help
Old 01-14-2004, 06:24 PM
richpinkham richpinkham is offline
Re: Manual trans removal on 91 2 wheel drive
I hope you have removed the shifter from the transmission or it will not move back far enough to get to the clutch. If you have then check the clearance between the body and bellhousing/transmission for room to move. And if everything is ok and the shifter is out and you have plenty of room then its prob stuck in the clutch disk and jest needs a good shot of WD-40 on the input shaft and parts (as best as can be done) and a firm tug.
Good luck
'02 PT Cruiser Manual trans- won't go into gear win_daddy PT Cruiser | PT Cruiser Convertible 0 08-17-2010 01:30 PM
2006 4.2L Manual Trans. redka88 F Series 2 01-04-2010 08:51 PM
98 Manual Trans - Transmission Overhaul steveryd ZX2 3 06-30-2009 05:05 AM
2000 2 door 4x4 5speed manual blazer 4 wheel drive issues... Settytb Problem Diagnosis 3 01-07-2009 06:53 PM
G35 Coupe 6-speed MANUAL and all wheel drive? WinterG20 Nissan 350Z/370Z | Infiniti G35/G37 Coupe 4 05-04-2003 08:52 PM
