Old 01-12-2004, 08:00 PM
MoshimoGTP's Avatar
MoshimoGTP MoshimoGTP is offline
Send a message via MSN to MoshimoGTP
Post PCM Diagnostics Results
There are the results of the PCM Diagnostic with a OTC Diagnostic Tool:
P0706 (D) - TRANS RANGE SW PERF
P0441 (B) - EVAP SYS NO FLOW
P0300 - MISFIRE DETECTED
P0122 (A) - TP SENS CKT VOLT
P0102 (A) - MAF SENS CKT LOW FREQ
P1374 (B) - 3X REF CKT (WHAT ARE THIS????????????????)
The PCM Was reseted by OTC and the SES Light come off. But 2 days later the SES Light come on again. I will diagnose again the PCM.
Comments?
Old 01-12-2004, 09:02 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
300 - Misfire - get some new plugs and wires and use plenty of dialectric grease
706-
Conditions for setting this code:
The transaxle Range Switch indicate a gear position other than Park or Neutral during startup
The above conditions are present for 2 consecutive setups
Easiest thing the book says to check is, make sure the PCM wireharness is ok. Also, if you have access to a scan tool, move the gear selector and see if the PCM corresponds to the selected gear.
Sounds like either a new PCM or a Trans Range Switch might be needed
441 - cant find in my book Might check to make sure your gas cap is working properly
122 - Throttle Position Sensor
The TP signal is one of the most important inputs used by the PCM for fuel control and most of the PCM - controlled outputs.
Inspect wiring harness
Once again a shop could probably find the problem easier, but the book breaks it down to bad sensor or bad PCM if no bad connections are found on the wiring harness.
102 - MAF sensor measures the amount of air which passes through it into the engine during a given time. The PCM uses the mass air flow info to monitor engine operating conditions for fuel delivery calculations. A code will set if the signal frequency from the MAF sensor is lower than the possible range of a normally operating MAF sensor. The freq. will vary within a range of around 2000 hertz at idle to about 10000 hertz at max engine load.
Once again the book talks about checking the connections to the sensors and PCM and replacing the sensor or PCM
1374- The 3x reference signal is produced by the ignition control. The ICM calculates the 3x reference signal by dividing the crankshaft position sensor 18x by 3 when the engine is running and the CKP sync pulses are also being received. The PCM uses the 3x ref. sig. to calculate engine rpm and crankshaft position at engine speeds above 1200 rpm. The pCM also uses the pulses on this circuit to initiate injector pulses. The PCM constantly monitors the number of pulses on the 3x ref circuit and compares the number of 3x ref pulses to the number of 18 x ref. pulses and CAM signal pulses being received.
If the PCM receives an incorrect number of pulses on the 3x ref. circuit, DTC 1374 will set and the PCM will use the 18x ref sig. circuit for fuel and ignition control.
Diagnostic Aids:
Poor Connection - inspect harness and connectors for improper mating
Damaged harness
Malfunctioning Ignition Coil
Replace Ignition Control Module
Replace PCM
This is just some info i got off my GM manual. Hope it helps alittle
Tim
Old 01-13-2004, 10:26 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: PCM Diagnostics Results
441 could be related to the return flow to the gas tank from the Throtle Body/intake system. COuld be a broken return line or clogged purge canister
Old 01-13-2004, 10:34 PM
GhostLake GhostLake is offline
The 441 could also be the evap purge solenoid.
Old 01-14-2004, 02:00 AM
MoshimoGTP's Avatar
these are bad news... or not???... =(
1999 sable fans not coming on long enough, PCM, CCRM. cooling timetrax Sable 5 06-05-2015 08:52 PM
Got P0601 Internal Control Module Memory Checksum Error replace PCM or RE-Programm? gujju Caravan | Voyager 1 09-30-2010 11:01 PM
No signal PCM diagnostic port spenser TrailBlazer | Trailblazer EXT 3 05-28-2010 09:49 AM
Crankshaft Sensor? PCM? Camshaft Sensor? elninoeso Ram Van 14 06-10-2009 12:19 AM
98 Ford Windstar GL Diagnostic Results - Need guidance Dizmatic Windstar 5 02-25-2007 04:07 PM
