Old 05-10-2010, 08:35 PM
spenser spenser is offline
Smile No signal PCM diagnostic port
2003 Trailblazer with 4200 engine. A friend changed the thermostat on his and he didn't disconnect the battery. Just moved the alternator out of the way. Now there is no signal at the diagnostic port. Is the PCM attached to driverside of engine? Pic would be nice. Also can somebody tell me what pins would show voltage at the diagnostic connection?
Wiring diagram would be great!
Old 05-11-2010, 11:51 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: No signal PCM diagnostic port
Check your fuses.
http://www.troublecodes.net/OBD2/
MT
Old 05-11-2010, 09:56 PM
OldSVTGuy OldSVTGuy is offline
The PCM is the aluminum box with three major wire bundles attached on the driver's side of the intake manifold. Like was earlier stated, better check fuses first.
Old 05-28-2010, 10:49 AM
The Roadie's Avatar
The Roadie The Roadie is offline
If the problem is that a scanner doesn't work when plugged in under the dash, it's almost always the CIGAR fuse under the hood. The OBDII connector shares power with the main cigarette lighter. Not mentioned in the Owner's Manual at all because GM doesn't respect the owners enough to use the port.
Bill Videos Build Thread
