Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 01-12-2004, 07:10 PM
JIMPOULOS JIMPOULOS is offline
Smile Looking to buy a 1999 Montana. RELIABLE?
I am looking to buy a 99 Montana and wanted to know if there are any common problems with the motor or tranny. Or any other major problems. Please inform me if you have any bad or good experience with this type of vehicle.
Old 01-21-2004, 09:02 PM
PTR97 PTR97 is offline
Re: Looking to buy a 1999 Montana. RELIABLE?
Watch out for the intake gasket leak, mine just gave out. Caused engine to over heat. Even had anti freeze changed at 50K. Appears to be a BIG problem with the 3.1 & 3.4 engines, along with the DexCool antifreeze. Otherwise I have been very happy with it. Non-maintenance items that have been repaired/replaced; water pump, washer pump. Has very poor heater, not very good air flow with full heat/vent setting.
Should I Buy NoPorsche General Discussion 0 09-11-2010 02:19 PM
1999 Montana won't start bat27 Montana/Montana SV6 1 07-06-2009 12:10 PM
1999 Montana Radio Reception fsmrdel Montana/Montana SV6 2 02-18-2005 01:22 PM
1999 montana transmission hard shift into overdrive bonga Montana/Montana SV6 5 11-03-2004 09:53 PM
1999 Montana Keyless Entry Programming losmorans Montana/Montana SV6 3 09-01-2003 10:31 AM
