Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 01-12-2004, 09:29 AM
williape williape is offline
engine removal
New to this forum. Glad it is here. Need to replace engine in 2000 sunfire 2.2 L OHC engine with automatic trnasmission. Haynes manual says you need to remove engine and transaxle together. Do you really have to or can you remove engine without removing transaxle? Any tip would be appreciated.
Old 01-13-2004, 08:34 AM
fire02's Avatar
fire02 fire02 is offline
Send a message via AIM to fire02 Send a message via Yahoo to fire02
Re: engine removal
undo engine mounts, electrical and plumbing, and all the other needed bolts, pull and lift, its out
02 Sunfire
Old 01-13-2004, 03:48 PM
I think that means, no you do not have to remove Transaxle (transmission) along with engine. Right? the engine can be removed alone by unbolting the mounts, rear bolts connecting the engine to transmission and unbolting the torque converter from the flywheel Thanks for your help.
All purpose cleaner to remove oil, grease, tar... mikecooper General Tools 3 02-15-2011 09:15 PM
93 Cx A/C removal & fuel / other lines. Engine Removal Pt.2! **56k grab a pillow** Hybrid93Hatch '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 03-05-2003 07:52 AM
Engine removal almost finished! Have a few Q's mdnnccivicrcr '88 - '91 Civic | CRX | Wagon | Shuttlee 11 08-25-2002 11:30 AM
Countach engine removal anderson Countach 11 03-09-2002 03:27 AM
93 325i engine removal labguy2776 3 Series 5 05-01-2001 10:50 AM
