Old 01-11-2004, 04:33 PM
xaw57 xaw57 is offline
Newbie with a common problem
Hi everyone!! New around here!!
I've got a couple a questions to ask.First I gotta say I don't know much about mechanics and more English is my second language...pretty hard to understand you guys sometimes.
First problem like many of you I've experienced idle problem. When I stop to a light after a minute or so the rpm goes weird: under 1000 but the car seems to cough. The only way I found to stop that is to press the gas pedal until rpm reaches 1500 then it's ok. But when the car does that the needle of the gas gauge goes straight up to the full up line??? And behind the car, the air coming out the exhaust pipe sounds a bit like a pop??
Second problem: what's the throttle body kit and how can I see it (under te car??)
Third one: the temp/gauge light is burn. how can I change it?
Thanks for your answers
By the way: 93 escort LX, 1,9L , new alternator, new radiator, new exhaust line/pipe
Xaw57
Old 01-12-2004, 09:58 PM
herefordman herefordman is offline
Re: Newbie with a common problem
In a nutshell, you should get a manual such as Hayners or Chiltons, it will help you a lot.
The throttle body is in the air intake pipe, just before it goes into the intake maniflold, car sounds like the timing is out, try getting a tune up done.
Newbie with a problem!! Icanfixit 1st Gen 95-99 11 09-16-2007 04:35 PM
newbie with radio problem on 88 cherokee Melissa B Cherokee 3 10-27-2005 04:35 PM
newbie with old(s) problem crayzee88 Eighty Eight 1 08-24-2005 02:55 PM
Newbie with tranny problems on 1999 WS JBTX Windstar 2 12-21-2004 10:56 AM
Newbie with a problem tonysuperstar Jetta/Vento/Bora 5 11-14-2004 03:48 PM
