Old 01-11-2004, 10:09 AM
mnwalleye mnwalleye is offline
Key ingition switch
I have a 93 Voyager that seems to have a bad ignition key switch. It went out all of a sudden. It seems very loose and sloppy from the off to the on /start positon. I do hear the fuel pump getting power but nothing at the starter. I pull the starter out and had it checked, it's fine. I then checked at the wire using a volt meter and hitting the energizer wire and the other one to ground while my son turn the key to the on postion, nothing. So I'm assuming the switch is bad and I'm wondering if I can safely jump the starter to get it to the dealer so the switch can be replaced. Can I jump the energizer wire to the + red positve lead with the switch on the on position just to get it started?
Has anyone had this problem?
Thanks,
Walt
Old 01-13-2004, 07:04 PM
hossierrun hossierrun is offline
Wink Re: Key ingition switch
Yes. Jumper the starter with the key all the way to start and drive it to a repair shop to get the key cylinder changed. It is a common defect.
Thanks,
Walt
Old 01-13-2004, 09:25 PM
Thanks, got the van hot wired and it started on the 1st attempt. Drove it to my mechanic who replaced the key cylinder, now I have 2 keys but I had cars back in the 70's with a door key and an ignition key so no big deal. My mechanic showed me the cylinder and the metal ring that drives the switch broke off so no way to fix it, just replace.
Thanks again, better to happen at home then on the road somewhere so I was lucky I guess.
Walt
Old 01-16-2004, 06:08 PM
That is the only disadvantage of replacing the key cylinder. A locksmith can reset the tumblers to match the old one, but it will cost you $50 to $75. I am living with two keys, myself.
Old 05-16-2004, 01:42 PM
wendyma wendyma is offline
How much did this cost you?
Old 05-17-2004, 09:05 PM
key core replacement
It cost me $89.57 for parts and labor, just glad it didn't happen to one of my kids when driving it out of town.
MNWalleye
Old 11-20-2004, 09:04 AM
ThanatosCV66 ThanatosCV66 is offline
How exactly did you jumper the the starter? I have the molding removed from my steering column. Do I leave the jumper wire on, and turn the key? Never hotwired a car before. Please help!!!
Old 11-21-2004, 01:45 PM
Problem was solved in this thread http://www.automotiveforums.com/vbul....php?p=2486982
Anyone having these symptoms, please look to this thread, has really good info.
Turn key and nothing. no dash lights or response from the key turn at all. grrrtyson Cherokee 3 04-26-2010 12:12 PM
Ingition switch buckroo LeSabre 3 11-14-2007 10:02 PM
Whats wrong with my 2003 alero? ingition switch? tinkgirl Alero 2 05-09-2007 12:58 PM
97 Pontiac SunFire Ingition Switch smokeyburnouts396 Cavalier Problem Diagnosis 1 12-07-2005 08:08 PM
I think I have a kaput ingition switch ... kents Park Avenue 1 03-11-2005 02:04 PM
