Old 01-11-2004, 09:43 AM
GTOJAY GTOJAY is offline
Twin Turbos
Does anyone know how the twin turbos work on a '92 GTO. Is one of them for low revs and the other one for high revs, or do they both boost at the same time? I wanna learn something guys. PLEASE TEACH...
"When I die, I want to die like my grandmother who died peacefully in her
sleep. Not screaming, like all the passengers in her car."
Old 01-11-2004, 03:51 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
they are the same turbo front and back, the reason there are 2 is because its easyer to twin turbo a V engine car than single turbo it. There is one turbo for each exhaust manifold.
Old 01-12-2004, 12:58 AM
ikOnone ikOnone is offline
yes they are 2 TD04 9b turbos. they are not sequential (aka they boost at the same time) they put out ~9psi for 91 - 93 and ~11psi for 94 - 99 (or until 00 or 01 if you count europe and japan). you can easily ($18) up the boost with a MBC to 14.5psi safely (aka stock guage is crap) and get 355 hp with any model. you can go as high as about 18psi peak to about 10psi at 7k rpm on the stock turbos. they are small so they drop off at high rpm (start dropping about 4.5k rpm i think).
chris
Old 01-12-2004, 10:16 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
An excellen article can be read here http://www.team3s.com/FAQturbobasics.htm
Resistance Is Futile (If < 1ohm)
Old 01-12-2004, 01:08 PM
Re: Twin Turbos
Wat does this mean?
"you can go as high as about 18psi peak to about 10psi at 7k rpm on the stock turbos."
I thought 7k rpm...was your PEAK ???
Old 01-12-2004, 02:24 PM
Re: Re: Twin Turbos
Originally Posted by GTOJAY
Wat does this mean?
the stock rev limiter on a VR-4 is at about 7.5k rpm i believe so that is you stock peak rpm. what i ment was peak psi of boost. you can go as high in boost as 18 maybe 20 after the turbos are fully spooled up (which happens very quickly) but when you get to higher rpms, you boost level drops.
Old 01-13-2004, 06:04 AM
oh ok, thanx bud. But you wouldn't want that psi on a stock turbo right?
Old 01-13-2004, 12:14 PM
Re: Twin Turbos
i have heard both ways, i would suggest going to www.steal316.com and reading the stuff about flow maps on there. basically, if you are pushing 18psi out of the stock turbos you are operating out of the turbos peak efficiency range and thus you are blowing a lot of really hot air in (which is bad, we want cooler air). i have heard that this is pointless but i have also heard people say that they gained power from it. i am sure that if you go to www.3si.org and do a search you will get more info than i can provide here.
it should be noted also that the stock fuel setup will not work at pressures above 14.5 psi or so on the stock turbos so you should make sure you have the fuel to back up the boost.
Old 01-13-2004, 02:39 PM
The1NamedMarc's Avatar
The1NamedMarc The1NamedMarc is offline
Send a message via AIM to The1NamedMarc
Re: Twin Turbos
DON'T RUN 18 PSI on stock turbos.
Twin Turbo Lamborghini Gallardo vs Twin Turbo Dodge Viper trev0006 Car Videos 0 05-07-2008 03:07 PM
Twin Turbo Lamborghini Gallardo, Twin Turbo Ferrari 355 drag racing trev0006 Car Videos 1 09-06-2007 05:12 PM
twin turbo WS6 vs. twin turbo supra doodad Camaro Discussions 17 03-14-2006 08:21 PM
300ZX Twin Turbo vs. Supra Twin Turbo Automobile Maniac General 31 08-10-2005 03:05 PM
300ZX Twin Turbo vs. Supra Twin Turbo Automobile Maniac 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 49 10-03-2004 10:28 AM
