Go Back   Automotive Forums Car Chat > Kia > Sephia
Old 01-11-2004, 09:27 AM
itstock itstock is offline
2000 Kia sephia runing like $%&* help!
My mom has a 2000 Kia Sephia, and recently her and my dad were cruising down the road and out of the blue, the check engine light came on,and teh car started spitting and sputtering. It has 68k miles on it. I also believe its throwing codes 8-9-11-& 18. when u let it idle it sputters down, and when u slightly rev it up it kinda knocks. We're thinking that the timing belt might have jumped a few teeth, could anyone give me some insight to what could be going on? thanks.
Old 01-17-2004, 02:59 PM
fordism fordism is offline
Re: 2000 Kia sephia runing like $%&* help!
I had the exact same problem last night mine also has about 67000 miles and started that same SH*T!! did you find out what caused it if so please reply and help me out. Ps. how do you pull the codes off of it. Thanks for your help. Fordism!!!
Old 01-19-2004, 12:44 PM
Found the problem on mine. It was a faulty spark plug wire on #3 I replaced it and damn I am running back to normal. I hope this helps you!
Old 01-27-2004, 01:42 PM
BondP BondP is offline
I went to auto zone to find the defective code on my kia 2000. They say it is #3 plug wire. How did you replace that wire.where are the plugs and wires on this car. i have never replaced them before. My car starting hesitation on accleration and ping. If any one had fixed same problem please reply
Old 03-08-2004, 12:00 PM
Re: Re: 2000 Kia sephia runing like $%&* help!
That little black cover on the top of the engine has I think 6 or eight screws in it. Remove that oand there will be 2 coils and 2 plug wires. the plug wires will be on the #1 and #3 plug wires.remove them and replace with the new ones. and you will be set. Also reset the computer by taking loose both battery cables and turnign the ignition on. and then let the battery cables be left off for at least 5 minutes. replace them and back to rollin again.
Old 05-21-2004, 08:54 PM
shoffy shoffy is offline
Re: Re: Re: 2000 Kia sephia runing like $%&* help!
Another note on that - it is suggested that you replace your plug wires every 30k. Of course, no one told me that!!! :-)
But... problem... not in aftermarket parts yet... so you have to buy from Kia. A whole set, around $60. Yuck! For plugs!!! :-)
Old 05-21-2004, 09:26 PM
jqcas jqcas is offline
Re: Re: Re: Re: 2000 Kia sephia runing like $%&* help!
no no no, sp wires shouldnt be no more than $8 from http://www.k1iadealer.com/santafe/parts_home_page.cgi
JQ
www.k-rev.com
Old 10-02-2004, 02:58 AM
SupaMan89T's Avatar
SupaMan89T SupaMan89T is offline
Send a message via AIM to SupaMan89T Send a message via MSN to SupaMan89T Send a message via Yahoo to SupaMan89T
On my aunts kia the valve cover gasket blew out and was leaking oil down into the spark plug chamber and causing it to miss.
Project Lexus Revive
2000 Kia Spectra fuel reset switch? fathairysmurf Spectra | Cerato | Forte | Mentor 0 03-07-2010 04:34 PM
help.. 2000 kia sephia rivera23 Sephia 0 02-16-2009 09:37 PM
2000 kia sephia fuel pump blkmrideon22s Sephia 2 02-04-2005 04:18 PM
how do i change fuel filter on 2000 kia sephia miranda728 Sephia 2 08-08-2004 10:49 AM
Fuel Filter 2000 Kia Sephia brdg826 Sephia 1 11-05-2003 01:16 PM
