Go Back   Automotive Forums Car Chat > Kia > Sephia
Old 12-16-2003, 10:37 AM
blkmrideon22s blkmrideon22s is offline
Question 2000 kia sephia fuel pump
i have a 2000 kia sephia and the car has sat for a year and now i'm planing to fix my car. well i tried to crank the car up and it tries to turn over but i the fuel pump doesn't it kick in. i ask some mechanic they said that a fuel pump realy could be bad or the pump it's just bad. how can i check to see if the fuel pump has went bad? if the fuel pump went bad how to i replace my fuel pump?
Old 01-07-2004, 09:45 PM
CARL WEST CARL WEST is offline
Im Not Actually Sure Because Its Been Avery Long Time But. Im Pretty Sure Its The Fuel Pump. You'll Have To Drain The Tank And Replace The Pump Which Once You Take The Old One Out You'll Know How To Put The New One In. Most Likely You'll Have To Change The Fuel Filter Too Or You'll Burn Up The New Pump In No Time. Your Float Will Probably Be Stuck To. Just Soak That In Some Carb Cleaner. It Sounds Like Alot Of Work But Once You Get Started On It You See It's Easier Than It Sounds. Have Fun
Old 02-04-2005, 04:18 PM
jlturner45 jlturner45 is offline
Send a message via AIM to jlturner45
I have a '96 Sephia, and I have tried everything to find out how to access the fuel pump, since I as well need to replace mine. Noone can seem to tell me whether I need to drop the tank, or if I can access it through a door under the backseat, and the service department at the dealers refuse to tell me, they want me to pay them to do it, but I want to do it myself. I would really appreciate any info anyone might have. Thanks.
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
2000 Tahoe LT Fuel Pump, Cats and Door Actuator ediesel_b13 Tahoe 0 05-14-2010 10:36 AM
2000 Kia Spectra fuel reset switch? fathairysmurf Spectra | Cerato | Forte | Mentor 0 03-07-2010 04:34 PM
Kia Sephia - Fuel Pump Reset Switch queenbee632000 Sephia 1 02-19-2006 12:24 PM
98 kia sephia fuel pump mikeb43 Sephia 1 10-18-2005 02:56 PM
