Old 01-10-2004, 02:18 PM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
Question Re Decals: not a very smooth result...
This question has haunted me for years... when I lay down a decal and smooth it out, even after drying, the surface of the decal is never glassy smooth like the surface I am applying it to. Is this normal? I don't think the roughness is very thick, so I intend to clearcoat over the decal and then polish, but I know some of you guys don't polish over decals. Which makes me wonder if I'm doing something wrong... because I would never consider my decal jobs to be showcase worthy after only laying down the decals. Do you guys see this same roughness, or am I missing something in the decal process? Thanks in advance.
I work slowly!
Old 01-10-2004, 02:28 PM
Zcaithaca's Avatar
Zcaithaca Zcaithaca is offline
fershizzle
Send a message via AIM to Zcaithaca
Re: Question Re Decals: not a very smooth result...
that is normal if you do not use microsol or micro set....try using these products and you will be very pleased with your results....Raymond wrote a very good tutorialfor this in the how to section
Zach
Old 01-10-2004, 02:53 PM
PRIVATEER's Avatar
PRIVATEER PRIVATEER is offline
Send a message via AIM to PRIVATEER
Decals are not normally real glossy even with the proper setting solutions. The only way to get a hi gloss ,is to over coat them. They should however have a little sheen,but not much.
Old 01-10-2004, 02:59 PM
DSM-Mark's Avatar
This is exactly what I have. I do use Set and Sol, so that wouldn't be the problem. I guess what I'm getting is normal. Thanks!
I work slowly!
not running smooth wilkinsj M Bodies 2 07-05-2009 12:45 PM
1-4,000 rpm's not running smoothly?? l.jonez.civic '88 - '91 Civic | CRX | Wagon | Shuttlee 11 10-12-2004 11:25 AM
1989 s10 4 cyclinder - motor not running smoothly e5028818 S-10 6 09-23-2004 01:25 PM
95 Astro not running smoothly hiway speeds rfloyd M Bodies 1 08-29-2004 09:31 AM
not running smooth blu65 Mirage 3 02-17-2004 12:36 PM
