Old 09-17-2004, 07:37 PM
e5028818 e5028818 is offline
1989 s10 4 cyclinder - motor not running smoothly
the truck starts up up and runs great for about 10 minutes
then it seems like its missing on the firing engine idles ok but when you give it a little gas it runs but spits and sputters
i changed plugs , coils , wires , cap rotor - engine getting lots of gas
is it posssible my time gears are gone
thanks for any tips or info
Old 09-17-2004, 09:45 PM
OverBoardProject OverBoardProject is offline
Banned
Re: 1989 s10 4 cyclinder - motor not running smoothly
I would imagine that you checked the ignition timing.
If you pop the valve cover off, and turn the engine back and forth a little by hand (this can usually be done with the fan belt, but don't force it) you can observe how far the crankshaft turns before the valves start moving... This should give you a good idea if yout timing set is worn out.
A compression test is never a bad idea when you have problems like that
Old 09-19-2004, 08:04 PM
Re: Re: 1989 s10 4 cyclinder - motor not running smoothly
i did check the timming it was off by a lot
and i set it on the timming specfied then the truck would hardly run
and the manifolds turn red hot
In order to get it idling correctly i had to set it of its timing
so my timing gears are most likely worn out
Is that coorect
Thanks for an answer
Old 09-19-2004, 08:53 PM
Banned
I've also seen the timing marks in the wrong place, Theres rubber in there that rots... They ocasionally slip on the shaft, when the keys shear, and even more often they are replaced with the wrong ones.
Sorry to say You will probably have to pop the left valve cover off to investigate further
Old 09-19-2004, 08:55 PM
Banned
Sorry I was thinking 6 cylinder, but you will still probably have to pop the valve cover
Old 09-20-2004, 10:44 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: Re: 1989 s10 4 cyclinder - motor not running smoothly
Is that coorect
Ummm....
You then didn't set it properly. You need to disconnect the timing advance wire from the PCM under the dash when you set the timing.
Then once it is set, you reconnect the wire and away you go.
Old 09-23-2004, 01:25 PM
Re: Re: Re: Re: 1989 s10 4 cyclinder - motor not running smoothly
Originally Posted by BlazerLT
Ummm....
I had a look under the dash couldn't find or don't really know what i, m looking for
can you give a an idea where - and color of the wire
thks
