Go Back   Automotive Forums Car Chat > Ford > Econoline
Old 01-10-2004, 12:20 PM
Phoenix723 Phoenix723 is offline
'90 Ford E350-Headlights Keep Burning Out
Driving down road last night, headlights go out. Switched to bright, they came on. Drive around parking lot, brights go out, too. Checked all fuses. Looked OK. Drove to Checker Auto Parts, bought two new headlights. Worked for about 20 miles. Brights were on, then go out. Switch to dims. Dims stayed on for the next few miles home. Haven't driven again, but assume these will go out as well, soon! All turn signals, interior lights, brake lights, everything else, works. I'm a woman, and I'm not real electrically inclined. Not a whole lot of money to take to a repair shop. Can someone help?
Old 05-14-2004, 06:13 PM
Doug Rodrigues Doug Rodrigues is offline
Send a message via MSN to Doug Rodrigues
Are the lights are burning out? Do they get very bright before they cease to function? Could be an overvoltage problem. Use a voltmeter and check the charging voltage to the battery. If the voltage is too high, the voltage regulator is defective. If the voltage is okay, then it could be a defective high/low switch, but that wouldn't cause the lights to burn-out. We need more information to give you an accurate answer.
Old 08-31-2005, 10:00 PM
MidNiteTOW MidNiteTOW is offline
Send a message via AIM to MidNiteTOW
IF Bulbs are burning out,overvoltage is likely problem,,but if bulbs are ok ( and I feel they may be)
Problem seems that it Should be Dimmer switch or wire harness connection (on floor under carpet or rubber mat)
Have a Great Day,, Steve
Headlights keep burning out.. shatter65 F-Body Problem Diagnosis 8 12-12-2008 04:50 PM
Headlights keep burning out!!! flyrc100 Camaro Discussions 3 10-29-2004 08:15 PM
High Beams keep burning out. mtdxx General Discussion 5 12-27-2003 07:19 PM
1985 300zx ecu keeps burning out ? daheightsawg 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 0 12-24-2003 06:33 PM
Why do my speakers keep burning out williemayes '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 03-27-2003 05:15 PM
