Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-11-2008, 10:35 AM
shatter65 shatter65 is offline
Headlights keep burning out..
I have a 1994 Camaro RS and I use the H4351 light by Sylvania. I have gone through a total of 5 headlights in the past 3 months. At $30 per light, this has to stop. Any suggestions as to what might be burning them out? I've tried installing them with and without the grease they offer at autozone. I just put the grease on the connection pointslike they say to do to stop overheating.
Thanks.
Old 12-11-2008, 10:55 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Headlights keep burning out..
any evidence of moisture in the plug area? is it the same side that burns out all the time? or is it both sides?
Old 12-11-2008, 08:11 PM
No, there is no evidence of moisture. Both sides keep burning out.
Old 12-11-2008, 08:57 PM
philly rs's Avatar
philly rs philly rs is offline
Send a message via Yahoo to philly rs
sounds like a short somewhere have u checked your fuse box? maybe pull the fuse or make sure u have the right size fuse in that slot....i could see the wires for one beingbad but both at the same time... maybe u hsould also check the wires where u connect the sockets at...(thinking your lights are like my 96)
Your import sounds like my ass after a night of mexican food..
And spraying aint cheating, its brining a gun to a knife fight!!
yeah, its a v6 RS...never mind the f1 badges lol
HYPSI87 u will be missed
Old 12-11-2008, 11:09 PM
I haven't checked the fuses because all the lights were working fine when I bought the car about 1 1/2 years ago. Then the fog lights stopped working.. and then the headlights started burning out. My best guess was a short in the wiring, but I have been turned off by the idea of actually pulling all the wire looking for the short. POS Camaro... You know.. it probably is just the wiring. My stereo is having a ton of problems due to wiring too. It's probably just too old.
Old 12-12-2008, 01:49 AM
Genopsyde's Avatar
The President
check the switch area then, since both the headlights and fogs are giving you problems.
Old 12-12-2008, 02:45 AM
Morley Morley is offline
And check the dimmer switch.
Old 12-12-2008, 10:21 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Do they seem a bit brighter then normal when working or dimmer?
Old 12-12-2008, 04:50 PM
They are always consistant in brightness.
