Old 01-09-2004, 07:55 PM
northflyer northflyer is offline
93 suburban won't start
Have a 93 suburban that won't start. Checked for spark and it is good. Did not hear fuel pump at start as usual. replaced fuel pump relay to no avail. Have just finished fuel pump replacemnt. Can now hear pump when key is turned but still will not start. Any ideas appreciated. Thanks
Old 01-09-2004, 09:41 PM
back2life's Avatar
back2life back2life is offline
Re: 93 suburban won't start
i have a 94 suburban and i have never heard my fuel pump run at start! Anyway check for fuel at the carb or throttle body whichever u have if u have tbi then check for fuel injector fuse or possible bad injectors? GOOD LUCK!
Old 11-17-2004, 11:34 PM
back2life's Avatar
hey there ! did u ever find out what kept your truck from starting ?if you did let me know because i havent found out whats keeping mines from starting
Old 01-19-2005, 12:38 AM
tirefryer93 tirefryer93 is offline
Make sure you have fuel flowing from injectors first. Have someone watch the injectors when you try to start the vehicle. If you have fuel and spark (at the plugs, importantly) then have the fuel pressure tested. Aftermarket and other-brand fuel pumps will not last whatsoever. Mine went out in less than six months. It hurt, but if in doubt, go with GM.
Old 02-18-2005, 02:18 PM
GMCMudBogger's Avatar
GMCMudBogger GMCMudBogger is offline
Try spraying starting fluid in the throttle body if it starts it's your fuel system obviously. Make sure you changed the fuel filter when you changed the fuel pump as well as the strainer, cheap insurance. If that is doesn;t seem to be it, check the wiring to the fuel pump and as a rule of thumb never run the tank emply or close to empty regularly, because the fuel is what keeps the pump cool, most pumps overheat and die prematurely because of this.
There is no substitution for horsepower, bigger tires and more lift! [img]
2002 Suburban - Motor Swap - Won't Start mrharris32 Suburban 5 09-22-2010 06:48 PM
2002 Chevy Suburban cranks, won't start adamj_rogers Suburban 1 06-17-2010 07:34 AM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
94 suburban won't start.. rodman C/K 4 04-27-2004 03:00 PM
96 Suburban won't start, unless... plnestel C/K 3 03-22-2004 06:36 AM
