Old 01-09-2004, 07:17 PM
supereclipse96 supereclipse96 is offline
What is the difference between turbo tranny and non turbo tranny????
I have a non turbo eclipse, And have been told that there is no difference between the turbo tranny and the non, except that the turbo
trannys clutch and flywheel are about two centimeters bigger. Is this true? I am also wondering do they have the same bolt pattern? If so can i use the turbo clutch and flywheel kit in my car?
Because if you have the same car i do you know that the turbo clutch kits are twice as cheap and cover more power ranges than ours do. I look forward to expert advice. Thanx.
I dedicate my life to the pursuit of speed.
Old 01-10-2004, 10:19 AM
kjewer1 kjewer1 is offline
AF - Advisor
If your screen name clues me in to the year of your car, the turbo and non turbo trannies are very different. Everything spins the opposite way On a 1g everything is laid out the same, and there is a chance they are the same trannies, but I dont know off hand that they are or are not the same.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-10-2004, 03:35 PM
Re: What is the difference between turbo tranny and non turbo tranny????
Thank you I will look into the 1st gen tranny and see if they match up. thanx again.
Whats the difference between a 180SX and a 240SX? uranium235powered 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 9 03-03-2005 06:32 PM
whats the difference between a 528i and the 528ia? hewtash 5 Series 4 05-19-2004 01:23 AM
Whats the difference between base, SH, and SiR models for 5th gen preludes? x_lude Prelude 2 03-21-2004 04:04 PM
Whats the difference between a d15 and d16 block? doug294 '88 - '91 Civic | CRX | Wagon | Shuttlee 9 01-13-2004 01:30 AM
Whats the difference between a coupe and sedan? iLuBSkylines Car Buying Q&A 2 09-26-2003 01:14 PM
