Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 01-09-2004, 06:34 PM
rekles17 rekles17 is offline
Send a message via AIM to rekles17
Question Oil in plugs, PLEASE HELP
While changing the plugs on my 94 T-bird I found that all four plugs on the left side of the engine had oil in them. Can it be anything else other than the pistons?
Old 01-11-2004, 06:11 PM
flunky flunky is offline
worn valve seals or a leaking head gasket. Make sure your oil has no water in it and that your coolant has no oil. If it is bad valve seals
its not so bad, either a valve job or a hot plug to aid in the burning of
the oil with the fuel can take care of the problem. If oil is found in the radiator,or water is found in your oil a head gasket may be your problem.
It takes a lot of missed oil changes and miles to wear out the rings in a
modern engine .
Old 01-11-2004, 09:55 PM
forcfed93's Avatar
forcfed93 forcfed93 is offline
Re: Oil in plugs, PLEASE HELP
How bad were they? Were the plugs fowled, was the car missing? Was the car running bad so you decided to check the plugs?
As mentioned above, it may be a head gasket. But that usually only effects on cylinder.
Give us some history on the problem! It may help narrow the problem down a bit!
Michael Albee - Prez
Super Coupe Club of IOWA
http://www.sccoia.org
1990 XR7 Auto
1991 SC Auto
1993 SC Auto
1993 Mark VIII (a.k.a. "The Winter Beater")
Old 02-19-2004, 02:29 PM
Zat-an-SC? Zat-an-SC? is offline
Send a message via Yahoo to Zat-an-SC?
I also have a 94 4.6 with the exact same problem (drivers side). I was told by a mechanic who I consider very knowledgeable that it is a common problem and a very simple fix. He said the oil only gets on the plugs as you're removing them. This is because the oil is coming from the valve cover gasket then dripping down into the hemi style plug hole. I haven't tried to fix mine yet. Let me know what you determine.
Lighter And Auxillary Plug Please Help Me TSTOCKING Ranger | Courier 0 01-06-2005 11:18 AM
1996 Ford Windstar Spark Plugs Please Help Alex12198 Windstar 15 12-01-2004 10:41 PM
CHANGING MY OIL FILTER {please help} D1RTCHASER Pick-Up 5 04-10-2004 04:24 AM
Oil leaking from oil filter....PLEASE HELP how2lose101 General Discussions 3 02-23-2004 06:19 PM
oil loss please help mrzuk1 Corolla/Matrix/Voltz 1 01-31-2004 08:36 PM
