Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-09-2004, 02:17 PM
Hyla1967's Avatar
Hyla1967 Hyla1967 is offline
Unhappy crankshaft sensor
My 1991 Bonneville is showing two symptons, one it has what seems to be a hesitation or miss while you are accelerating and secondly when you first start out the car shakes. The local Sears is telling me crankshaft sensor, I like to be sure that the symptons match the dignosis before I ok repairs. I have been taken for a ride a few times, mostly because i am a woman. Any opinions or anyone have this problem?
Old 01-09-2004, 07:26 PM
daman daman is offline
Re: crankshaft sensor
ses light on
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80
2004 Chevrolet Impala LS 3800
"ALWAYS"...... full synthetic!!!
Old 01-09-2004, 08:13 PM
Hyla1967's Avatar
No light at all comes on
Old 01-09-2004, 08:42 PM
thecommi thecommi is offline
Send a message via AIM to thecommi
Camshaft sensor is a strong possibility since it is a very common sensor to fail on the 3800 motors. Usually what happens is there is alittle magnet pressed into a gear that is mounted to the camshaft, when the magnet comes around, the sensor picks it up and closes a circuit, which in turn sends a signal back to the computer. well.... the magnets like to fall out, some times all the way, and other times just enough that the sensor doesnt pick it up all the time. that is usually a big job, but no way to know for sure unless you accually take the thing apart.
Old 01-10-2004, 10:55 AM
Hyla1967's Avatar
ok so I have had that replaced and it still is doing it, when you start out it almost feels as though you are riding on rumble strips. It only last about 2-3 seconds and then the car rides fine. Any suggestions?
Old 01-13-2004, 06:55 PM
shrty_19 shrty_19 is offline
Send a message via Yahoo to shrty_19
Did you also have the camshaft interrupter-magnet replaced?
Old 01-16-2004, 05:46 AM
bridget36907's Avatar
bridget36907 bridget36907 is offline
Re: Re: crankshaft sensor
ok what is that and where is it?
2005 Grand Prix GT
3800
1995 Chevy Caprice
LT1 5.7
1986 Dodge Ram
Old 01-17-2004, 08:27 PM
Bravo Garage Bravo Garage is offline
Re: Re: Re: crankshaft sensor
The cam shaft magnet is on the cam shaft sprocket inside the timing belt housing. It cost $12 at the dealer for the part. It takes a couple hours to replace for a novice. When the magnet on mine fell out, the magnet went all the way to the oil pan. I replaced the coil pack, cam shaft sensor, crank shaft sensor, then found out that it was the magnet on the cam shaft sprocket. My car was running fine with out it, but the SES came on, then I checked the codes, which stated all items listed above, when I asked a professional mechanic for some assistance, the recommended the crank shaft sensor, (this apparently causes lots of different problem when it goes bad) I have heard of several different symptons when the crank shaft sensor has gone bad. If SES light comes on get the codes or have them looked up for you, this will eliminate choosing the incorrect part for the fix.
Old 01-18-2004, 05:48 AM
ok i am sorry you are saying cam shat he said crank shaft..let me know thanks
2005 Grand Prix GT
3800
1995 Chevy Caprice
LT1 5.7
1986 Dodge Ram
Old 01-18-2004, 09:15 AM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
It sounds like a misfire to me!
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Crankshaft position sensor GregGP Grand Prix 1 03-25-2010 04:33 PM
Crankshaft Sensor? PCM? Camshaft Sensor? elninoeso Ram Van 14 06-10-2009 12:19 AM
Replacing O2 Sensor and Crankshaft sensor on 96 Grand Am rjfeathers Grand AM 1 08-19-2007 10:35 AM
Location of crankshaft sensor and throttle position sensor rudy49 Grand Cherokee | Grand Cherokee SRT8 2 01-26-2005 01:56 PM
crankshaft sensor dreamlady Eighty Eight 1 07-09-2003 04:58 PM
