Old 01-09-2004, 10:29 AM
heathershonda heathershonda is offline
Send a message via Yahoo to heathershonda
Question Face plate wont rotate
I have a Kenwood rotating face plate stereo. I just took both amps out of my car...and now when I start the car the face wont rotate. I know there's this little code where you push the left hand corner 2 or 3 times to flip it around, but that doesnt work.
If anyone knows how to flip this face around...help me out.
Thanks
Old 01-09-2004, 11:03 AM
tibby01 tibby01 is offline
if it is motorized, you could have popped a fuse while takin the amps out. check to make sure you dont have the blue remote turn on wire for the amp just dangling behind the radio, because if it touches anything metal, a fuse will go. so wrap up that turn on wire good. then make sure all the red/white outputs coming form the radio have something covering their metal ends. after all that is done, check the fuse on the back of the radio...if its bad(hopefully it is) just replace it. are you getting any power at all to the radio?
Old 01-09-2004, 12:22 PM
When I took the amps out, I left all wires there...well I covered all the ends with electrical tape. Nothing is loose behind the stereo at all. All I did was take the amps out, and now when I start the car, face wont flip around.
Old 01-09-2004, 01:45 PM
pheurton-skeurto pheurton-skeurto is offline
Re: Face plate wont rotate
did you check the fuse in the back of the head unit though, that could easily be the culprit. and a quick fix.
1997 Honda Prelude Base
18G Turbo - 8 Psi
GReddy EVO Catback
1995 Honda Civic LX
Bone Friggin' Stock
Old 01-09-2004, 10:20 PM
are you getting any power to the radio at all?
and if the fuse is blown, hopefully it is because you just momentarily touched power to ground, and not because a wire is cut somewhere from being tugged on.
Old 01-10-2004, 10:18 AM
No I havent checked the back of the unit yet...i'll go and do that.
I dont know if this had anything to do with it or not, but i had to have my car's battery jumped, would that have blown something?? *dont laugh, i'm a girl* lol
Old 01-10-2004, 11:18 AM
unusualcivic's Avatar
unusualcivic unusualcivic is offline
Send a message via AIM to unusualcivic
any kind of a sudden surge can blow a fuse. regardless pop that cd player out and check
84 Civic 1500S
engine- T3 D16a1 with built bottom end in the works
interior- MOMO seats, Sunpro guages, RCI 4-point harness,
sound system- clarion DXZ825, RF Fanatic P's RF 351S, 1 Eclipse SW6123DVC (currently saving for another)
exterior- satin black in progress
Old 01-13-2004, 12:01 PM
Update...checked everything, there is power and there is no loose wires. You can hear the motor trying to flip the face when I start the car...but still nothing moves.
Old 01-13-2004, 12:10 PM
thats bad then, a peice could of broke.try taking the face plate off and putting it back on according to the manuaal...maybe your doing some thing wrong.
Old 01-14-2004, 09:04 AM
I had a perfessional install it, and it's been in my car for at least two years with no problems till now. Just thought maybe it had to do something with taking out the amp.
Old 02-04-2004, 11:43 AM
Finally got it to rotate...it was locked. Dont know how that happened but thanks to eveyone who gave me advice.
Another question...since I took out the amp for the inside speakers, how can I wire the speakers back up so they can play with the amp?
Old 02-05-2004, 05:19 PM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
wait a min, you took out the amp, now you're putting it back in? uhh make up your mind.. anyways to get it going again, just hook up all the wires (make sure they are the right ones + to + and - to - and make sure your remote 12v supply wire is hooked up to turn your amp on when you start your car.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 02-08-2004, 10:46 PM
No...I want the speakers the play without the amp, so sorry I messed up a word.
I just wanna hear sound, instead of nothing when I drive.
Stereo Face plate 1991 can it be replaced? mackrist M30 0 10-15-2005 03:41 PM
Dashboard gauge face plate for 2000 impala Vitalssj Impala | Impala SS 6 10-09-2005 10:44 PM
Face Plate Removal 02 Civic herdem Interior | Audio | Security 2 06-08-2005 03:59 PM
remote mounted in dash face plate? wastegate1 Car Audio 1 03-27-2005 07:43 PM
Face Plate TakeIt2DaHouse88 Car Audio 1 08-16-2003 08:17 PM
