Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-09-2004, 08:02 AM
ronhap ronhap is offline
1997 aurora seat heater
driver seat heater not working. light does not come on. fuse ok,both sides uses same fuse,pass side works fine
Old 01-09-2004, 06:32 PM
oldsdad oldsdad is offline
Send a message via Yahoo to oldsdad
Re: 1997 aurora seat heater
This is a common problem with the heated seats.Usually the driver side goes first as it is the one with the most use. As your in and out of the drivers side more often the wiring breaks down and the seat stops working. Only fix I have heard of is to replace.
Old 01-10-2004, 10:08 AM
Keith1 Keith1 is offline
Each seat heater is controlled by a heater module located under each seat. You can swap one side for the other to determine if this is the cause. If not check heater resistance, open means no heating element circuit, ie broken element wire.
Remove the seats by cranking the height high and moving the seat forward. Take the track bolts out from the back of the seat. Alternately you can keep the track in place and just unbolt the seats.
Old 10-01-2005, 09:48 AM
Cool 47 Cool 47 is offline
Re: Re: 1997 aurora seat heater
what does the heater module look loke? there is a lot of stuff under the seat?
97 Jetta GL Seats Smakdab '97 - '03 1 05-11-2010 01:49 PM
Fitting seats? Sqwkr '96-'00 Civic 0 03-16-2010 07:51 PM
2001 aurora passenger locks windows mirror sidneydean Aurora 1 05-01-2009 07:27 PM
1997 aurora lots of problems skit0321 Aurora 31 02-20-2006 10:47 PM
Drivers Seat & Seat Heaters Joek510 C/K 2 12-21-2003 09:50 PM
