Go Back   Automotive Forums Car Chat > Automotive Art > Remote Control Cars
Remote Control Cars Questions, comments or discussions on the wonderful little vehicles.
Old 01-09-2004, 03:34 AM
rome4 rome4 is offline
motor swap
Hi, i'm new, I just bought a XB Tamiya Frod Lightning. I am buying a 19T Trinity Chameleon motor and I want to know exactly what I have to do the swap the engines. I know there is a solder side and plug side...but looking at the new motor, it doesnt look like there is connectors/plugs that come with it. I want to know if I have to do any soldering or anything like that to swap out the 540 or if I can just bolt it right on. Please help me out.
Old 01-09-2004, 04:06 PM
Psman32@af Psman32@af is offline
Send a message via AIM to Psman32@af Send a message via Yahoo to Psman32@af
I dont think that is a direct motor swap. If i remember corredctly, teh taimya XB's are powered by a 380 sized motor. I dont think you could put a 540 into an xb easily. Also, if it is a 380 motor currently in there, there is a very small chance that the electronics could even handle a 540 motor. I say first, check to see if teh motor is the same size as your 540, if it is, you will need to solder something, to make it work, if it is not a 540, i would suggest not trying to make it work.
2005 Mercury Grand Marquis. 230 WHP 249 ft-lbs as measured by a mustang dyno.
Old 01-12-2004, 03:43 PM
Re: motor swap
Actually its a stock 540 Tamiya motor in there, and I just recently made the swap this weekend. It was a couple screws and plugs and that was it. But thanks for your help anyways.
Old 01-15-2004, 01:19 PM
Re: motor swap
huh, last i knew they didnt use the 540 sized motor... looks like iw as misinformed. How does it run? also, be careful as you could fry the electronics, or resistor if it is a mehincal speed contorl unit.
the views and opinion expressed in this post are my own and in no way reflect the opinion or views of DTE Energy (company madated statement)
Old 01-16-2004, 03:36 PM
Re: Re: motor swap
I'm not fully sure as to how it runs. I ran it out in the snow (bad idea) and found that it didnt grip AT ALL but it did go MUCH faster then the stock motor. I can asure you that it will go much faster when the snow melts. I am quite worried with the MSC, i SHOULD get a ESC but we'll see how it goes. I dont want to put a 100 dollar item on a 250 dollar toy. like i said, we'll see how it goes.
2002 Suburban - Motor Swap - Won't Start mrharris32 Suburban 5 09-22-2010 06:48 PM
help please !! motor build question!! Derrick12556 Mirage 2 12-27-2009 05:31 AM
Lemans motor swap xxGriffonxx LeMans 4 10-27-2009 08:28 AM
engine swap Cadillakin'98 S-10 1 10-22-2009 09:33 AM
350 motor swap bowtieballs2000 Performance 0 03-09-2009 10:26 PM
