Old 01-09-2004, 01:29 AM
Robert Reid Robert Reid is offline
Aftermarket Tachometer
I want to install an aftermarket tach in my 98 Escort 1.6 Zetec.
Question; Where do I hook it up to?
Is there a wire coming out of the ECU for it, if so what color is it, does it come from the top or the bottom of the ECU?
Can I hook it to the coil in the engine compartment, if so where is it and what color is it?
Old 01-10-2004, 01:55 PM
robh1217 robh1217 is offline
Re: Aftermarket Tachometer
I have the very same question about the '97 Escort sedan with the 2.0 motor... Any help that can be given will be greatly appreciated.
Old 03-13-2004, 12:43 PM
urban off-roader urban off-roader is offline
I can't seem to find the answer to this either.. I know this is an older post so if you've found out by now let me know.
Old 03-13-2004, 06:33 PM
vette_7t9 vette_7t9 is offline
OK, remove the dash, since all the gauge wiring is in a wiring box sumwhere under the dashboard. Older cars such as oldsmobiles and buicks hav the wiring box in a small openable compartment on the dash, but newer ones have to remove dash board cover. Now, the tricky part is, which color to plug in the tach?!?!?!?!?? if it doesn't come with a tach standard, that can be tricky. But try pluggin em all in. After all, it is quite worth it since u get to rev the engine right?
Aftermarket Tachometer 1994 Cutlass Cutlass Series 0 03-09-2005 02:14 AM
94 1.8L mirage: how to install an aftermarket tachometer Aeh_Lecks Mirage 1 03-08-2005 03:26 PM
aftermarket tachometer install shadowracer666 Cavalier 1 02-09-2004 09:12 PM
1991 Honda Civic aftermarket tachometer installation. civichbca91 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 12-11-2003 10:20 PM
Aftermarket Tachometer DX4life Engineering/ Technical 3 02-06-2002 11:02 PM
