Old 01-08-2004, 09:30 PM
Kinked210's Avatar
Kinked210 Kinked210 is offline
Send a message via MSN to Kinked210
Mugen Racing Chip...is it worth it?
I was wondering if those chips actually help as much as they say they do.
I saw on ebay one for like $20.00 that raised the max RPM to 10000! And the VTEC kick in at 4400 RPM. Is this true? Anyone ever installed one?
Old 01-08-2004, 11:01 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Mugen Racing Chip...is it worth it?
it's not a real mugen racing chip...you can't get anything mugen for $20
Empty Pockets Racing Member #1
Old 01-08-2004, 11:13 PM
Kinked210's Avatar
Well...
Do the chips really work that well? How does it work? How much does a real chip cost?
Old 01-08-2004, 11:22 PM
95civicCX's Avatar
95civicCX 95civicCX is offline
I think that this is about the only thing you can get from mugen for under $20, and they're $12 a piece.
I don't even think that mugen makes a chip. Only thing electrical like that would be the ECU and it's like $1,200.
This is specially mapped to the fuel mixture, ignition timing, and combustion. The rev limit is increased to 9,100 rpm from the normal 8,400 rpm, and the VTEC valve timing changeover point is lowered to 4,700 rpm from the normal 5,300 rpm. It is highly recommended that reinforced valve springs be fitted if this E.C.U. is used.
95 Honda Civic CX
SOHC VTEC
AEM High Flow Fuel Rail
B&M Adj. Fuel Pressure Modifier
B&M Fuel Pressure Guage
APEXi Exhuast
Del Sol Shifter
B&M Shift Stabilizer
H&R Race Springs
KYB AGX Adj. Struts
Eibach Pro Control Front Strut Bar
Arospeed Rear Upper and Lower Strut and Tie Bars
26mm Sway Bar
Rear Disc Brake Conversion (4 Tony)
Specialty Products Adj. Camber Kit
16 Inch Quantum Tec Alloys
215/40 Nitto 450
Old 01-08-2004, 11:24 PM
Kinked210's Avatar
So these $20 "racing chips" on Ebay...what do they do?
Old 01-08-2004, 11:27 PM
95civicCX's Avatar
I'd say they don't do much of anything for $20 man.
95 Honda Civic CX
SOHC VTEC
APEXi Exhuast
Del Sol Shifter
H&R Race Springs
KYB AGX Adj. Struts
26mm Sway Bar
215/40 Nitto 450
Old 01-08-2004, 11:33 PM
Kinked210's Avatar
Alrighty. I thought it sounded fishy. By the way...how much is it gonna cost me for a decent intake/header/exhaust and how much HP will it give me?
I drive a 93 Civic Ex (D16Z6)
Old 01-08-2004, 11:40 PM
95civicCX's Avatar
Are you not the same one that "had" the B16 in his 93 Ex?
95 Honda Civic CX
SOHC VTEC
APEXi Exhuast
Del Sol Shifter
H&R Race Springs
KYB AGX Adj. Struts
26mm Sway Bar
215/40 Nitto 450
Old 01-08-2004, 11:42 PM
95civicCX's Avatar
How much are you looking to spend? Cheap, Mid-range, Top of the Line stuff?
95 Honda Civic CX
SOHC VTEC
APEXi Exhuast
Del Sol Shifter
H&R Race Springs
KYB AGX Adj. Struts
26mm Sway Bar
215/40 Nitto 450
Old 01-08-2004, 11:43 PM
Kinked210's Avatar
This is that guy's friend. We just used the same name on here...I don't know..i dont wanna spend alot
Old 01-08-2004, 11:44 PM
Kinked210's Avatar
We both drive 93 Ex's...except his is has a B16..but mine looks cooler
Old 01-09-2004, 12:01 AM
95civicCX's Avatar
OK....well still need a price range but I'll tell you some anyway.
This intake's got a COOLNESS rating of like 12/10 and it's only $72.00 at King Motorsports.
DC Sports 4 into 1 Header. $260.80 at NOPI Online Store.
Your on your own on the muffler, just don't make it sound too much like a pissed off bumble bee. Don't go with a cheap ass muffler.
95 Honda Civic CX
SOHC VTEC
APEXi Exhuast
Del Sol Shifter
H&R Race Springs
KYB AGX Adj. Struts
26mm Sway Bar
215/40 Nitto 450
Old 01-09-2004, 12:07 AM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
as far as the max rpm goes... hell you could have a chip that would raise the max rpm to 20,000. this doesn't mean the engine will be able to do it without blowing into a million pieces...
LS1 RX-7 Zoom Zoom
Old 01-09-2004, 12:19 AM
Kinked210's Avatar
thanks alot 95...
so the chip is a big no unless im willing to spend alot of money right?
Old 01-09-2004, 12:30 AM
95civicCX's Avatar
Well, I've heard good things about chips as long as you go with the right one. I've heard the JET performance chip is nice, but I couldn't really tell you anything about them.
95 Honda Civic CX
SOHC VTEC
APEXi Exhuast
Del Sol Shifter
H&R Race Springs
KYB AGX Adj. Struts
26mm Sway Bar
215/40 Nitto 450
10:1 CR is this possible and whats the benefits and is it worth it? ty423 Engine 13 04-16-2002 10:22 PM
AEM bypass valve is is worth it??? PoisonFangs '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 03-14-2002 12:35 AM
