Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 01-08-2004, 08:47 PM
Wing-Nut Wing-Nut is offline
Olds 88 royale won't start / car alarm
- When turning the ignition key the car will not start. I can hear a clicking under the dash, followed by the car alarm going off.
- The battery voltage is 12.34 volts.
- could it be something else?
Old 01-08-2004, 10:58 PM
greengumby greengumby is offline
follow the cables from the battery to the fuse box and tightn the ends down to make sure their is a sold contact also check the other cables leading to the starter
make sure all grounds on the cables are secure
also are you disarming the alrm when u start the car ?
it shouldnt be going off when u start the car ..does the alarm have the starter kill feature? if it does it might be thinking ur stealing the car and it goes off thus disableing the starting
try also to pull the main fuse on the alarm to temp disable it ..it should have a inline fuse from the battery ..then try to trouble shoot the starting problem with the alarm temp disabled
do i safely
Happy Motoring
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 04:20 PM
1988 Olds Delta 88 Royale won't start. Ultimist Eighty Eight 12 04-20-2008 02:13 PM
96 GrandAm Won't Start & Alarm goes off constantly JM22 Grand AM 1 03-17-2006 08:41 PM
1990 Delta 88 Royale Won't start big_bobcat_42 Eighty Eight 3 08-24-2004 02:11 AM
