Old 01-08-2004, 12:32 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
best engine build for boost
looking to get an engine and i am boosting it.....i want to know which one will give the best gains assuming each one is built to handle boost
B18C1
LS/VTEC with B18C1 head
B20
CRVTEC with B18C1 head
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 01-08-2004, 09:25 AM
BLU CIVIC's Avatar
調整器
anyone?? just need a quick answer
The name's Adrian
2011 CR-Z - Stock
Old 01-08-2004, 10:04 AM
VeNomGSR VeNomGSR is offline
Send a message via AIM to VeNomGSR
well i wouldnt recommend boosting with a c1 ...or anything with a c1 head...Too high of compression for boosting unless u have the money to get forged pistons and sleeves( THEN u could prolly run a good amount of boost...i know someone with arias forged 10:1 comp pistons and sleeves...and hes running 21 psi)...but thats alot of money. Id just go b18b and while the block is out replace all the piston rings and seals...get some APR studs and eagle H rods...and ur prolly safe to run 8-10 psi daily driven....14psi if u wanna push it...
Old 01-08-2004, 11:23 AM
MastaCivic MastaCivic is offline
Go LS if you don't plan on keeping the car or at least keeping the car running for more than 2 years.
But if your like me, I'm going with a b18c1 and then turbo later on because I'm probably not going to buy a new car for another 3-4+ years.
Pretty much if your going to have a mass amount of funds in the next few years, go with the b18c1(or go with this engine if you plan to have the money later)
Otherwise go with the LS, it's a LOT cheaper to turbo.
Old 01-08-2004, 12:38 PM
BLU CIVIC's Avatar
調整器
Re: best engine build for boost
i actually plan to build up the engine and keep it till it falls apart....every 4 months getting it retuned to make sure everything is runnin straight....car is mainly going to be used in auto-x and a weekend cruiser.....and the whole car is gonna be in the shop for the next year or so being put together.....that way it'll be done right.....
but with proper internals and what not.....which set-up would be best?
The name's Adrian
2011 CR-Z - Stock
Old 01-08-2004, 06:06 PM
supranc312 supranc312 is offline
Send a message via AIM to supranc312
B18C1
B20
from the 4 ur interested in boosting i suggest goin with the crv motor. its simple and very strong. if u want to be cheap u can go with an ls turbo. they are really strong as well and if u put after market pistons and rods in it they can hold around 20 psi safely. just go with a b16 tranny or somethin and do some head work such as porting it and a valve job and itll be great for the money.
Old 01-08-2004, 06:11 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
matter of fact i doing a b20 with type r head myself with turbo....its at golden eagle right now getting arias pistons 8.5-1 and bored 20 over with golden eagle sleeving...let me know how yours goes i get pics on her soon as motor gets back to my house
Old 01-08-2004, 11:31 PM
Re: Re: best engine build for boost
I dunno bout everyone else, but I believe if I was going auto-x I would go with a b18c1. The b20 conversion is mainly(not always) for going BIG hp. Like 300+ all motor or 500+ with a turbo. The b18c1 can do anything, it can be a dialy driver,a weekend racer,a high hp drag motor, or a medium to high hp auto-x motor. It's also slight lighter than a b20(notice I said slightly) and there are a lot more aftermarket options.
Old 01-09-2004, 01:09 AM
lol b20 can be a daily driver to and all the other things you said....any b series part will bult on a b series motor....maybe you should master more in a b20 before you say anything else...lol
Old 01-09-2004, 01:24 AM
95civicCX's Avatar
95civicCX 95civicCX is offline
I hear that the b20 with a b16 is a good combo, or maybe h23/h22 combo?
95 Honda Civic CX
SOHC VTEC
AEM High Flow Fuel Rail
B&M Adj. Fuel Pressure Modifier
B&M Fuel Pressure Guage
APEXi Exhuast
Del Sol Shifter
B&M Shift Stabilizer
H&R Race Springs
KYB AGX Adj. Struts
Eibach Pro Control Front Strut Bar
Arospeed Rear Upper and Lower Strut and Tie Bars
26mm Sway Bar
Rear Disc Brake Conversion (4 Tony)
Specialty Products Adj. Camber Kit
16 Inch Quantum Tec Alloys
215/40 Nitto 450
Old 01-09-2004, 08:50 AM
BLU CIVIC's Avatar
調整器
so if i was going to go with the CRVtec set up....what would be a good/best head and tranny?
The name's Adrian
2011 CR-Z - Stock
Old 01-09-2004, 10:01 AM
Hybrid1990crx's Avatar
A good head for the money would be a b16 head for the b20. I think getting the type R head is a bit too expensive. And a good tranny would be something with long gears to aid the turbo in spooling up real good.
Old 01-09-2004, 10:21 AM
BLU CIVIC's Avatar
調整器
so my best bet would probably be a b18c1 head and ls tranny??
The name's Adrian
2011 CR-Z - Stock
Old 01-13-2004, 08:02 PM
Smokn91HB Smokn91HB is offline
Send a message via AIM to Smokn91HB
well, if you have a good amount of cash, i would do the crvtec resleeve it, forged internals.. that
+turbo = good setup. if you want cheap than deff. go with stock ls turbo on 10-12 psi.
Old 01-15-2004, 10:31 PM
Ok you made a funny But anyways, I never said that a b20 couldn't be a daily driver, I just said that in my opinion a b18c1 can be made into a daily driver or any of the other things I mentioned a lot easier than a b20 becuase of the head swap on a b20. Just in my opinion, I would go with an engine that can get good power and have the ability to rev high without having to do as many mods to it. Its just that most people who go with a b20 swap are looking for some major power, and in auto-x you don't need 300+hp(but it would be nice ) Also it can be confusing to some people without laying it out on a silver platter to them that when you search for parts, make sure you get the right stuff to work with the head for your ecu, fuel, etc. and then a totally different look-up for new pistons,rods, etc. for the b20 block, and then maybe even another look-up for whatever tranny your using.
Nissan?s VQ Engine Receives Ward?s 10-Best Engines Award for 13th ... - Al-Bawaba Automotive News Automotive News Desk 0 01-04-2007 12:30 AM
Nissan VQ engine makes Ward's 10 Best Engines list for 2006 - AME Info Automotive News Automotive News Desk 0 03-27-2006 04:10 AM
Best engine swap for a 94 accord Lx ? nitroaccord20 Engineering/ Technical 2 10-30-2002 10:11 AM
Best engine setup for turbo? Grendel Engineering/ Technical 1 06-17-2002 11:05 PM
Best Engine Choice For A P10 & P11 dieselpower General 12 05-28-2002 09:13 AM
