Old 01-07-2004, 10:37 PM
taylor2527 taylor2527 is offline
1994 z28 electrical system help (stereo)
hey guys, i am having problems with my car stereo. i have a jbl 1200.1 powering 4 subs and a rockford 400a4 powering speakers, and my alternaotr can not keep everythign charged up. it has a 140 amp alternator in there which makes me wonder whats using up that much power in my car? i dont think that my stereo is that mazssive by any means just good, but i want it to work alot better, i cant even turn it up all the way before the 1200 watt amp cuts out because it cannot get enough power. im planning on buiying a 200+ amp alternator because i think that should solve my problem, but does anyone else have any other suggetsions? thanks
Old 01-07-2004, 10:44 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: 1994 z28 electrical system help (stereo)
capacitor, think capacitor. go get yourself a 2 farad capacitor, 1.5 at the least. if you want to go all out get one for each amp. you definitely need a cap for the jbl.
Old 01-08-2004, 02:59 PM
RABarrett RABarrett is offline
WRONG!!! Think wire size, wire size. The smaller the wire, the more voltage lost in the wire, and the more of your power will become heat. Check this... Using a digital voltmeter, check the voltage at the battery and then check the voltage at the amp, with the power turned up. If the difference exceeds more than .6 volts, the connections are the problem. Same with the ground connections. If the voltage on the negative side exceeds .6 volts to ground, these connections also need addressing. Capacitors work well as bandaids in most cases. They have their place, but not as a bandaid. Ray
Old 01-08-2004, 07:41 PM
hey thanks for the input, im gonna try the connections with a volt meter and then see how that works. i was also wondering about my car in general though, i dont think there would be alot of stuff in there that would take a lot of power from the alternator, because you can see my volt guage going down and not rechraging fast enough, and i dont think my stereo is draining it that badly, but who knows. more replies welcome
thanks
Old 01-08-2004, 07:51 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
friend of mine was running a 1500watt alpine and a 600watt mtx, he had a 2 battery setup and the higher output alternator.
Old 01-08-2004, 09:29 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
the standard drain on your battery would be around 5millivolts with everything turned off. with everythin on and the engine running, you should be putting out around 14volts. but yeah, make sure you are using heavy guage wire, i think 4 guage for that much power is reccomended, but i would call crutchfields tech help on that one. they are really helpful. i have used them before for my wiring problems, and i work on wiring problems at a dealership lol.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 01-09-2004, 08:51 AM
thanks guys, im lready using 4 guage wire but im gonna try somehtign this afternoon, tanks for the help
1994 camry flooding out. help? kris10 Camry/Camry Hybrid/Vista 1 04-17-2010 07:09 AM
1994 Dodge Ram Van 15 Pass... Electrical? MeadowLark8 Ram Van 3 04-09-2009 08:20 PM
1994 Z28 Camaro vs. 1994 LT1 Vette WeirdRich Camaro Discussions 2 01-20-2005 10:23 AM
93 Camry Electrical system help.. Linearity Camry/Camry Hybrid/Vista 0 12-12-2004 05:55 PM
Electrical System Help gregc '88 - '91 Civic | CRX | Wagon | Shuttlee 9 04-05-2004 03:15 PM
