Old 03-11-2003, 03:22 AM
gregc gregc is offline
Electrical System Help
I have a '89 Civic SI that is giving me some trouble. While driving first the radio will quit then lights will dim and then the engine quits. When you try to restart nothing happens. If yo jump it, it will run fine for awhile and then a week or so later same thing. The battery is fairly new and the alternator is brand new (2nd one in last year). Any help? Thanks/Greg
Old 04-03-2004, 04:56 PM
JapPrecision JapPrecision is offline
Banned
Re: Electrical System Help
Have you checked the coil?
Old 04-04-2004, 08:58 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
Re: Re: Electrical System Help
the coil is going to have nothing to do with the battery dieing like that... its likely its either the battery or alternator have them checked out first... if they are ok make sure all your wire connections are good...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 04-04-2004, 09:05 PM
1989_cash_eater's Avatar
1989_cash_eater 1989_cash_eater is offline
RE: Electrical Problems
I think you should check to see if any connecters to your altenator, battery, or starter a loose. I had trouble like that before and after a battery and 3 altenators later, I found out that my starter, which was sticking, caused major damage to my altenator and battery, and just like your car, it was becoming a major pain-in-my-ass.
Old 04-05-2004, 01:01 AM
Banned
Re: Re: Re: Electrical System Help
What is your rationale on ruling out the coil? It is part of the “wire connections”—and ultimately a link in the electrical system in regards to the alternator and battery.Sometimes, a faulty coil can become intermittent from cold to hot, resulting in a short in the ignition system when the coil warms up (This means the car will stall when warmed up). Also, if there is any moisture residing in the coil, it could be rotten and causing problems. Jeef, did you read Gregc’s post..? He said his alternator is brand new and batt fairly new. Those 2 are already ruled out. Gregc, Try cleaning the coil mount (which is it's ground) and see if it makes a difference. Make sure every connection in the vicinity has a clean ground. Test the voltage at the battery terminals. If it's not at least 13 volts or more (with the car running), then your battery is not receiving anything from the alternator. I'm not sure if that particular honda has a built in voltage regulator or not, (probably does), but either way, I would look directly at the wiring that is coming from the alternator and check it 100%. Especially the larger cable (alternator charge output).If the alternator isn't charging anything up, then it must be something that leads from it(Yeah, I agree with you here, Jeef). Maybe if you checked the wiring, a new belt, and some belt grip, so the alternator wil have a good spin, and you've replaced the wiring to the battery, you might get some more time out of it. --Dont underestimate the importance of a solid ground connection!
--Be cool, stay in school--
Old 04-05-2004, 01:22 AM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
If it was the coil(from my experience) you wouldnt even be able to jump the car.
KoRnSaQ
Old 04-05-2004, 02:49 AM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Sounds like a bad ground to me. Check it
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 04-05-2004, 09:34 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
also, just because you have 13-14 volts from ur battery doesn't mean anything....it has to have proper amperage also. Ur battery could have 13 volts but no amperage (current) or power to start the car.....just a thought.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 04-05-2004, 12:26 PM
Banned
True,true.
Old 04-05-2004, 03:15 PM
Mojoe Mojoe is offline
I had a 67 Camaro that did that, turned out to be the starter.
Need HELP! Try to start and electrical system goes dead. Turn on head lights and the. klein444 Crown Victoria 10 08-26-2018 01:23 PM
hey i need some help in electrical systems Anil General Discussion 1 12-05-2006 05:21 AM
Please Help with Electrical System/Charging Problem :( Purple_Haze Silverado 7 10-06-2005 10:00 PM
93 Camry Electrical system help.. Linearity Camry/Camry Hybrid/Vista 0 12-12-2004 05:55 PM
1994 z28 electrical system help (stereo) taylor2527 Camaro Discussions 6 01-09-2004 08:51 AM
