Old 01-07-2004, 10:23 PM
cx-r cx-r is offline
noise increase with rpms???
what could be causing an electricity like noise coming through the speakers which increases with the increase of the engine speed? could it be the position of the ground wire? when i swithc the rca jacks into the other in/out holes on the amp it goes away but only my rear speakers work then? please help, thanx, goran.
Old 01-08-2004, 12:41 AM
tibby01 tibby01 is offline
check to make sure oyu didnt run any signal wires next to power wires. they should be run down two seperate side of the car. also, check that ground wires werent pinched and are exposed when you covered them up.
Old 01-08-2004, 12:01 PM
starkfu's Avatar
starkfu starkfu is offline
Send a message via ICQ to starkfu Send a message via AIM to starkfu Send a message via Yahoo to starkfu
Re: noise increase with rpms???
ok, first did you upgrade the ground at the battery and behind your radio? if not do that.
next, where did you run RCA's even if your power is on the other side factory wires can induce noise, make sure you use quality cables.
next, check to make sure no speaker wires have exposed wire anywhere but the speaker, i have seen this cause the engine whine.
Good luck.
***If knowledge is power, then a god am I***
<<former PH abyss member>>
1991 Acura Integra GS mods:
Tokico Illuminas
Eibach Sportlines
ES bushing kit
Mugen RTA bushing
Sprint RCA bushing
Power slot rotors and EBC pads
Gutted
Blown motor
Looking for B18C5
1994 Honda Accord EX
KYB AGX
Eibach Sportlines
Alpine CDA-9835
Just bought this car, more to come.
Old 01-10-2004, 12:52 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
This old wives tale will never die, I guess
Old 01-10-2004, 01:14 AM
well, with unshielded wires it wont. even shielded wires can pick up bits of interference too.
Old 01-10-2004, 11:11 AM
unusualcivic's Avatar
unusualcivic unusualcivic is offline
Send a message via AIM to unusualcivic
MECP states that power cables, and signal cables should be a minimum of 18" apart, if running parallel to each other. If you run a signal cable across a power cable at 90 degrees, it will not pick up interference.
84 Civic 1500S
engine- T3 D16a1 with built bottom end in the works
interior- MOMO seats, Sunpro guages, RCI 4-point harness,
sound system- clarion DXZ825, RF Fanatic P's RF 351S, 1 Eclipse SW6123DVC (currently saving for another)
exterior- satin black in progress
Old 01-10-2004, 11:23 AM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
just run the power line on one side of the vehicle, and the rca's and signal on the other or through the middle, this shoud do it.
Old 01-10-2004, 11:57 AM
starkfu's Avatar
Re: Re: noise increase with rpms???
This is fundamentally correct, but it's not fail safe, if you HAVE to have them closer then 18 inches, cross them at 90 degrees, but it's not a guarantee that it won't pick up noise.
Tokico Illuminas
Eibach Sportlines
ES bushing kit
Mugen RTA bushing
Sprint RCA bushing
Gutted
Blown motor
Looking for B18C5
KYB AGX
Eibach Sportlines
Alpine CDA-9835
Old 01-10-2004, 12:40 PM
anything that lessens the chances of alternator whine is good in my book
84 Civic 1500S
Old 01-10-2004, 03:16 PM
ok, i do have my cables next to each other, but the noise was not there before. it was fine for a while after i installed everything. now it is really annoying if i have my cd unit off.
Old 01-10-2004, 03:33 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
I would say that would probably do well. Upgrade the magic three wires, get larger protection on the wires, check grounds, check all wiring.
Old 01-10-2004, 04:25 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
ah yes..so true my friend..
I love them sub wufers
MPG increase with Performance chip willard1 4Runner/GX470 1 12-07-2008 06:10 PM
rumble from front end that increases with speed jpdykes Alero 11 04-01-2005 11:19 PM
20 Hp Increase With Chip On E-bay? SPARKY0114 Frontier | Navara 1 03-18-2005 07:58 PM
Road noise increasing travis2822 Blazer 3 02-12-2005 07:35 PM
