Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 01-07-2004, 10:22 PM
jlampitt jlampitt is offline
Thumbs up Hesitation solved
I thought I'd follow up to my post of a few days ago where my 98' Tacoma (4x2, 4-cyl) was having weird hesitation problems. (See post of the same topic...)
I replaced the plugs and wires as suggested, that didn't do anything to remedy. Took it to the dealer and they fiddled with it for nearly two days.
Ended up replacing the throttle position sensor and are having me run two cans of some awful toxic fuel line cleaner called "BV-208 44K".
Seems to have fixed the problem. I noticed they replaced the PCV valve as well.
Symptoms listed in the tech notes are as follows.
"Found TPS (Throttle Position Sensor) not working properly. Found high fuel pressure and pressure readings jumping around on test drive. Found rough idle. There were no engine codes."
Anyway, hopefully someone can use this information in the future if they have a similar problem.
Old 03-04-2004, 12:53 PM
dfskinner dfskinner is offline
Quick question, How much did the dealer charge you to do the work, and replace the fuel throttle sensor.
Thanks in advance,
Dennis
Old 03-11-2004, 08:42 AM
Was the fuel filter, hadn't replace it since 70,000 miles. Replaced, and hesitation is gone.
Thanks
Dennis
'95 Town car ABS light on and hesitation olopezm Town Car 5 12-02-2010 07:30 PM
99 neon crazy hesitation when I turn right?!?! gohann 1st Gen 95-99 4 05-29-2010 08:05 PM
86 camaro irocz hesitation posiman F-Body Problem Diagnosis 4 02-05-2010 06:31 PM
V6 2002 Mustang hesitates when accelerating lcmidas Mustang Problem Diagnosis 1 04-06-2009 09:59 AM
2002 windstar hesitation-solved d2m1 Windstar 2 04-05-2008 09:47 PM
