Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 04-01-2005, 11:49 AM
jpmwjm jpmwjm is offline
Question Oil pan Change on 2000 Ford Ranger
I own a 2.5 L 4 cyl. 2000 Ranger. The Oil pan cracked along the plug. I need help finding a pan to fit. What model years are compatible? Also what is involved in the change? (Ex: Does the engine have to be pulled?,Etc.) Thanks in advance for any help.
Old 04-02-2005, 09:30 AM
rodeo02 rodeo02 is offline
I should be a pretty easy job. There is plenty of room around & under the 4cyl rangers. I'm not sure if the 2.3/2.5L share the same oil pan, but I'm guessing you will need a 1998-2001 ranger 2.5L oil pan. Did it crack from the oil pan drain bolt being over tightened?
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
