Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 01-07-2004, 04:06 PM
NordicLight NordicLight is offline
Question Oil cap or PCV valve...
I brought a Montana ´97 back to Sweden that I'm trying to keep rolling (not too easy given the spare part prices here..). Anyway my 3.4L engine has recently started to "die" when it gets up to working temperature. This phenomena stops when I loosen the oil fill cap. Is this because the PCV isn't working or what?
Besides, I love this roomy van that makes Volvos look like "beetles"
Old 01-11-2004, 06:45 PM
Boddingtons Boddingtons is offline
Checking the PCV valve is simple enough. Lift it out, and stick a small screwdriver up the end of the PCV valve that goes into the engine. The little door should open and spring back freely. If it's sticking, you can either soak the hole unit in gas to try and clean all the gunk off it, or replace it (they're inexpensive).
Hope this helps....
Old 01-13-2004, 03:08 PM
Unhappy Checked PCV
I checked the PCV valve and it seems to work fine. Think it was replaced at the same time the manifold gasket was fixed...
I guess the valve leads vapours out... is it related to idle rpm? My problem only occurs when the engine is idling
Old 06-09-2004, 03:37 AM
Zebe9's Avatar
Zebe9 Zebe9 is offline
re:
I would suggest checking CAREFULLY all the vacuum lines for possible leak firs.
Greets
Zebe
Differences between PCV Valves CCMphysician General Discussion 5 01-13-2010 02:14 PM
PCV Valve Replacement CCMphysician General Discussion 0 01-13-2010 01:36 PM
Oil coming out of Dipstick and breather?PCV valve? ChevroletR Engineering/ Technical 6 06-27-2004 10:48 AM
