Go Back   Automotive Forums Car Chat > Toyota > General Discussion
Old 01-13-2010, 12:31 PM
CCMphysician CCMphysician is offline
Differences between PCV Valves
Is there any appreciable difference between PCV valve brands? I wanted one of the higher end brands of PCV valves, but my local Advanced Auto Parts was out of stock, so I used the Purolator brand.
Thank you in advance,
CCM
Old 01-13-2010, 12:37 PM
danielsatur danielsatur is offline
Re: Differences between PCV Valves
As long as you don't have oil blow-by contamination on your MAF, IACT, and Air filter.
Old 01-13-2010, 12:44 PM
Originally Posted by danielsatur View Post
As long as you don't have oil blow contamination on your MAF, IACT, and Air filter.
I am relatively new to car repair. Would you mind explaining this to me?
-CCM
Old 01-13-2010, 12:52 PM
The PCV valve is a check valve, it's job is to allow PCV gas and to block oil.
During the Air filter replacement, did you see any oil on your air filter?
Old 01-13-2010, 12:57 PM
No oil on the air filter. I don't quite understand the block oil statement. Would you please explain it a bit more explicitly to me?
Thank you for your help, I really appreciate it.
-CCM
Old 01-13-2010, 01:14 PM
I found an article on it: http://www.auto-repair-help.com/auto...entilation.php
Thank you again,
CCM
Tags
pcv , purolator , valve
