Old 01-07-2004, 12:52 PM
Virus9 Virus9 is offline
Send a message via Yahoo to Virus9
need carb help ('84 Z28)
The choke plate isn't moving at all. Where do I start?
Old 01-08-2004, 12:21 AM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Re: need carb help ('84 Z28)
is it eletric choke or manual?
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 01-08-2004, 02:22 PM
BigJustinZ28 BigJustinZ28 is offline
Re: Re: need carb help ('84 Z28)
it would be electric. Mine is starting to act up and come open after the car is warm. I really wish I knew how to fix it but I hate messing with quadrajets. cleaned it and lubed all the parts I could see of it. its getting a lil better , hopefully it will go away lol (how often does that happen ??? lol)
1984 Z28 = 305 HO w/ 700R4
flowmaster , k&n filter , B&M Megashifter
91-92 z28 dress w/ 94 z28 wheels
1997 Camaro Z28 = LT1 w/ LT4 Conversion w/ Hot Cam
52mm T/B , SLP CAI , SLP Shorties .Eibach Springs, KYB GA Shocks.
SS Hood , Suncoast Creations Spoiler , F1 Camaro Wheels.
30th Ann. Style White with Orange Stripes.
Old 01-08-2004, 02:38 PM
RABarrett RABarrett is offline
These units get a bad rap since most of the problem is that it is not well understood. The choke blade is closed by a bi-metallic spring in the housing. When the spring cools, it contracts, pulling the blade closed by the linkage. When the cold engine is started, the vacuum break, or chokd pull-offoperated by manifold vacuum, retracts, partially opening the choke, and allowing the cold engine to breathe. As the coil warms, the choke opens, further leaning the mixture, and allowing the engine idle to gradually drop toward normal idle. The current necessary to warm the coil comes from the ignition switch circuit. When the engine starts, oil pressure rises, closing the switch, and allowing the full current to warm the coil. Another circuit, a prove-out circuit, operates the choke light. Current flows from the ignition switch, through the light to the choke coil, which provides a path to ground, for the light. When the oil pressure rises, full battery voltage is applied to the coil, warming the coil and, since there is voltage now on both sides of the choke light, the light extinguishes. Now to your problem. Which part of this scenario does your car not do? Having an understanding of the problem will allow me to assist with a repair. Also, never lubricate a linkage. Simply clean it with carb cleaner, and be sure it is free to move. Lubrication tends to attract dirt, increasing the chance of the linkage binding. Please get back to me. Ray
Old 01-08-2004, 03:20 PM
mine just seems like sometimes the car is doing whatever it does to keep the idle up when its cold after its warmed up and the car idles about double what it should. If I cut it off in neutral while its doing this sometimes it will diesel. It seems like its been improving since I cleaned it all and wd40'd it. Any ideas ??? I had no idea all that stuff happened to work the choke.
need carb help doctorheat General Discussion 2 12-14-2007 03:44 PM
need carb and gas mileage help clevernickname C/K 3 02-25-2005 07:12 AM
new '84, need some help rmz Celica 1 01-31-2004 11:23 PM
