Old 01-07-2004, 08:11 AM
jeandre jeandre is offline
Arrow Caster Adjust
I want to know, How am I adjust the front caster of o 2wd Silverado?
Old 01-08-2004, 04:07 PM
RABarrett RABarrett is offline
Re: Caster Adjust
If yours is typical of the breed, the kits will need to be installed if the alignment is off... Ray
Old 05-16-2004, 12:46 AM
TheJamster1 TheJamster1 is offline
Re: Caster Adjust
From 1988 to 1998 you have cams in the upper control arms. Some have the cams some don't. The ones that don't, you have to buy them, install them and align. The slots in the frame clips that the cam bolts go through have a hole with a slot stamped in it. It takes a special tool or an air chisel and a rotory file to slot. Not a job for a shadetree. The newer models are easily adjustable if you know how too. But all is in the process of alignment. You cannot adjust camber or caster in most cases without adjusting the toe after, or you will wear the rubber off your tires.
1994 Accord EX caster problem xxGriffonxx Accord/TSX/Accord Hybrid 4 11-09-2010 01:18 PM
For Sale New adjustable fuel pressure regulator Malbe3 Parts for Sale 0 08-07-2010 07:32 PM
Need help with 327 valve adjustment gr8hse67 Chevrolet Classics 6 04-04-2010 03:28 PM
How to adjust valves? lazerphreak Engineering/ Technical 1 05-08-2009 07:22 PM
Caster - Camber Adjustment / Ball Joint Replacement mrbill3 Cherokee 2 05-12-2005 12:26 PM
