Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-07-2004, 01:42 AM
darkerdayz darkerdayz is offline
Send a message via AIM to darkerdayz Send a message via MSN to darkerdayz Send a message via Yahoo to darkerdayz
t25 vs. to4e
ok, i've done my research and i know that a smaller turbo will give you a quicker spool than a larger turbo, but the larger turbo will give you the option to run a higher boost than a smaller turbo. my question is this, lets say that the t25 turbo produces an extra 50 whp @ 7 psi. will the to4e turbo also produce that same 50 whp @ 7 psi on the same engine, or will it produce more? would it all depend on the engine (i.e. on a smaller engine would it produce the same but on a larger engine it would produce more)? any help would be greatly appreciated because it would really save me some money.
friends don't let friends drive stock
Old 01-07-2004, 09:19 AM
cougarsvt1's Avatar
cougarsvt1 cougarsvt1 is offline
Send a message via AIM to cougarsvt1
Re: t25 vs. to4e
Depends on the motor. A T25 is really small turbo, its kinda hard to compare a T25 to a T4. Night and day difference...
Turbonetics Dealer !!
Turbo kits for $3,100.00....GSR/LS/EX/SI
All kits come with injectors/Timing/ FMIC/ Ball Bearing Turbo's
We have these in stock!!!!
T3/T4E54, 0.63 A/R, Ceramic BB, super series, stage II Turbine........price $1,170.00 shipped
T3/T4E50, 0.48 A/R, super series, stage III Turbine....price $719.21
Evolution Wastegate kits for....$200.26 shipped...including all hardware
[email protected]
937-336-1462 ask for Stephen
Old 01-07-2004, 10:59 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Re: t25 vs. to4e
yea it is hard to compare a t-25 and a t04e, but i would say that it will make a little more hp at the same psi on the same motor.
1
Shift_BOOST
97 s14
Old 01-07-2004, 11:11 AM
MastaCivic MastaCivic is offline
Re: Re: Re: t25 vs. to4e
1
I would say it would make quite a bit more hp on the same engine. A t04e is a lot bigger turbo, so it will be forcing a lot more air into the engine at the same psi.
Old 01-07-2004, 01:58 PM
cougarsvt1's Avatar
Re: t25 vs. to4e
At different RPMs it will make a big difference(T4E). That T25 would be done and over when the T4 really boosts up. A good Comp map would tell us perfectly what the difference would be.....Im just lazy today and dont want to look.
[email protected]
T25 vs. T28?? HoosierDrifter Technical 10 03-13-2006 05:43 PM
t3/to4e outlawinacivic N2O | Turbo | Superchargers 2 07-23-2004 12:59 AM
T25 vs. 14b fitting Rob80 Engine, Transmission and Drivetrain 1 07-28-2002 03:38 PM
Z32 T25 Turbo ty423 Engine 11 10-21-2001 09:37 PM
T25 Turbo ty423 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 0 10-20-2001 05:40 PM
