Re: Door panel removal
Yea its pretty easy, just wedge out the window controls, and the plastic frame around the door handle, then the contorls for those pop off the plastic, next theres the handle in the middle of the door. Pull the little oval cover off and theres 2 screws you need to remove. After that near the side view mirrior, on the inside is a plactic piece. You might have a hard time getting it off, its just snap on but dont break it. From there just basically pull the pannel up a little bit, it will move up a tiny bit. Carefully try to seperate ir from the door. A flat head screw driver or some kinda wedge might help. Theres about 8 tabs connecting it they snap off so just be carefull not to rip em off the inside of the door. Maybe try starting @ the bottom, i know theres 3 tabs 2 corners 1 in middle...Good luck with that if all goes well it should take 5-10 min. To put it back together make sure you pound all around the door and snap all tabs back in then work in reverse.
