Old 01-06-2004, 05:26 PM
fractal fractal is offline
need help in understanding english!!!!!!!!!
Just please, dont laugh too much) For several days I'm siarching information about engines, more actually about increasing horsepower. In some articles I've read phrases "blueprinting block", "port and polish head", "sleeve block". There is no way I can translate them to my language. Could anyone explain me in more understandable language what all these phrases mean. Thanks in advance.
Old 01-06-2004, 05:55 PM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
Re: need help in understanding english!!!!!!!!!
to "balance and blueprint" an engine is to take very exacting steps in the building of the engine. meaning all the parts are the exact same size and weight. (balanced). People balance an engine because parts that rotate will not rotate truly if one side of that part is slightly heavier than the other. It will "wobble" to be less than precise. Even in an item, such as the crankshaft, which is supported by bearings along portions of its length, the rotating part will try to wobble and cause excessive bearing wear. So, to prevent this, all the parts are carefully measured, and weighed so that they are all the same and they are all correct.
to "blueprint" an engine simply means to build it to some specification. This could be a factory specification, the specifications of someone’s racing engine or one of the ones listed in a book. In its most basis sense, a blueprinted engine is any engine built to a plan.
I would never laugh at someone simply because they don't understand english unless they are acting stupid otherwise. I can explain it further if you wish, but I chose to keep it simple.
Mustangs are nice, but I'd rather have one of these...
Old 01-06-2004, 06:01 PM
Thanks for your fast answer. Now at least one of these phrases is really understandable.
Old 01-06-2004, 06:04 PM
which one is not as understandable, maybe I can help.
Old 01-06-2004, 06:12 PM
You didnt say anything about "port and polish head", "sleeve block".
Old 01-06-2004, 06:24 PM
oh yeah, sorry.
to "port and polish" the cylinder head means to enlarge the intake and exhaust ports and polish them for better air, fuel, and exhaust flow.
this usually involves changing the valves as well.
to sleeve the block, means to insert metal tubes into the cylinders to re-inforce the engine.
The block is overbored to accept the sleeve ... once the sleeve is installed you fit standard pistons (+.000) so the combination of the sleeve and remaining cylinder wall equates to the standard cylinder wall thickness but the sleeve is actually harder than the cast wall.
Old 01-06-2004, 06:40 PM
So as I understand sleeving helps to bring cylinders to factory size. But will the engine work long enough comparing to new engine? Maybe even longer?
Old 01-06-2004, 06:47 PM
454Casull 454Casull is offline
Re: Re: need help in understanding english!!!!!!!!!
Originally Posted by MustangRoadRacer
oh yeah, sorry.
Not a very good idea to polish valve ports now. On the intake side, if the ports are too smooth, fuel will adhere to the sides. On the exhaust side - well, after a few trips, the ports will be coated with carbon so it won't really matter if you polish them or not.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Sleeving actually increases the durability and strength of each cylinder. It isn't necessary to use stock bore sizes - you can have them smaller or bigger.
Old 01-06-2004, 06:58 PM
yes, I know that the intake system must maintain some level of abrasiveness to aid fuel atomization, but he asked what it meant.
a sleeved engine will last longer than a regular engine if it is done right.
but sleeving isn't usually done for reliability, it is done for strength, like in race engines.
Old 01-06-2004, 07:11 PM
here's a picture of a shiny ported and polished head.
Old 01-06-2004, 07:25 PM
Thanks for your answers. I knew a little about engine blueprinting, porting and polishing. But sleeving is something new. I haven't heard anyone doing this in my country. Is it expensive? I'm planning to buy 99 eclipse. Lots of performance mods are in my list. Would it be a good dea to sleeve engine or is it a waste of money. The car has ~50k miles.
Old 01-06-2004, 07:41 PM
sleeving is only neccesary if you want to have a lot of nitrous or a turbo with a lot of boost pressure.
Old 01-07-2004, 11:05 AM
The Dude The Dude is offline
Sleeving your engine is used for lots of stuff besides performance. 18 Wheelers and other industrial engines have sleeves because they are rebuilt often. When cylinders get badly scored and you dont have money for a new block, machine shops throw a sleeve in your cylinder, then just resize to match and helps fix the problem. Also Aluminum blocks use iron or steel sleeves to provide wear for the cylinder.
Old 01-08-2004, 05:36 PM
I meant only neccesary on an eclipse.
there are many uses for cyl. sleeves.
Need help understanding turbo surge from lack of preasure (air flow maps help) curtains Engineering/ Technical 0 05-01-2010 06:53 AM
Need help understanding backside, offset, etc. tahoerob Tires and Wheels 2 08-16-2006 01:42 PM
Need help understanding how to diagnose F/P BigGee Aerostar 0 02-09-2006 10:28 AM
Anyone good at or like football?(I need help understanding lingo:P) Janet Reno COMPLETELY off-topic 26 06-10-2004 10:55 PM
Need help understanding something. rare-air23 General Discussion 6 10-11-2002 07:54 AM
