Old 01-06-2004, 02:39 PM
LesM LesM is offline
'95 GSX 5sp - broken cruise control
The cruise control light does not come on, and the cruise control does not work. I looked for a fuse for cc but could not find one.
I would appreciate any suggestions for troubleshooting.
Thanks much
Les
Old 01-07-2004, 03:28 PM
kjewer1 kjewer1 is offline
AF - Advisor
More than once I have seen a maladjusted cruise control (CC) clutch switch. There are two clutch switches. One is activated at the bottom of its travel (clutch in), for the start safety feature. The other is at the top of the clutch pedal travel (clutch up) and that is to deactivate the CC when you put the clutch in. On my particular car, the switch was so close to the edge, that just the weight of the pedal would trigger that switch on bumps and turn off my CC. And I Could get CC to work again/light to come on unless I lifted up on the clutch pedal with my toe and turned it on, lol. In fact, try that next time you are driving. Might be a quick way to see if that is the problem. If not, I would still readjust that switch. OTher possibilities are the motor connector is unplugged (you'll find that motor unit under the hood, at the end of the mess of cables). Thats all I can think of off the top of my head... Hope it helps, Good luck.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-07-2004, 04:43 PM
Re: '95 GSX 5sp - broken cruise control
Thanks for your response.
It seems that the switch that enables cc intermittently fails. I try it a few times, and the little light goes on. cc then works. So, it seems I have a bad switch.
Old 01-07-2004, 04:54 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Re: '95 GSX 5sp - broken cruise control
or a loose connection, or the switch needs to be adjusted...
horn/cruise control uspres2020 Escort 10 02-17-2010 06:06 PM
94 Ram no cruise controll mrkabokieman Ram Pickup | Ram SRT10 3 08-16-2009 04:36 PM
Cruise control freak out cobraprince 3000GT/Stealth 13 03-23-2009 11:41 AM
1998 Zx2 Cruise Control Problems ddppci ZX2 1 02-17-2009 11:59 AM
broken cruise control on 93... acurac27a Integra 3 07-21-2006 05:53 PM
