Go Back   Automotive Forums Car Chat > Cadillac > Catera
Old 01-06-2004, 10:43 AM
anttef2 anttef2 is offline
Question Catera problems
I have a '00 Catera, I have a problem with the headlights. Every once in a while they tend to stay on. I can have my daytime running lights on and the headlights would be on with the DRL. Even if I turned the car off they would stay on. Can anyone help me with this? On top of all of that, the only way a mechanic can help me...they tell me that the lights have to be on when I take it to them to get a diagnostic reading!
Old 01-18-2005, 09:16 AM
cateragal cateragal is offline
Unhappy Re: Catera problems
My 1999 Catera is also doing this. The running lights wouldn't turn off. Tried removing the fuses; read the owner's manual for information; hit the Internet to research but found no information. Totally ran down my battery. Recharged the battery, and BEHOLD the running lights started working properly. Two days ago, January 16th, again couldn't get the running lights to turn off. This time, I popped the hood, disconnected the battery cables, let it sit overnight, then reconnected the battery cables and had no problem with them. I thought maybe cold weather might be affecting them, as the temps here have dropped to single digits and it was also very cold the first time it happened. ANYBODY OUT THERE HAVE ANY CLUE???
Old 01-18-2005, 11:32 AM
Re: Re: Catera problems
Hey, I finally got that corrected. It was actually the fuse for the daytime running lamps. I went to GM and had a new fuse ordered for about 10-20 dollars and once I changed it, I havent had the problem since. Try that, it should work. I was going through the same thing you were..disconnecting the battery and and everything else...so try buying a new fuse. That should be it.
Old 01-18-2005, 01:50 PM
Re: Re: Re: Catera problems
Really? Great! Thanks for the heads up. Will call the dealer and see if I can get a new fuse. Sure do hate popping the hood on these cold mornings and reconnecting the battery. Appreciate the help!
Old 02-28-2005, 04:37 PM
Talking Re: Re: Re: Re: Catera problems
Hey, just check to see if you it was the fuse and you got that corrected.....
Need Advice on the Catera GoBenB Catera 1 09-03-2009 07:38 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 07:38 AM
Catera Problems len730 Catera 0 07-31-2008 02:23 PM
Catera Problems jpfein Catera 0 11-08-2005 04:37 PM
