Old 01-06-2004, 08:02 AM
smcelhe smcelhe is offline
Transfer Case noise in 4WD
I have a 99 Silverado with 62,000 miles on it.....I am getting a noise from the transfer case when I engage the 4wd (manual lever on the floor). The sound is going to be hard to explain......sort of vibrating/running noise sound. If I pull back slightly on the 4wd shift lever the sounds stops.
Any ideas????
Thanks Shawn
Old 01-06-2004, 11:04 PM
NWChevyGuy's Avatar
NWChevyGuy NWChevyGuy is offline
Re: Transfer Case noise in 4WD
Mine used to do that in 2 wheel drive. Its the bottom of the shift lever vibrating agaist the transfercase linkage.The way I solved it, was I disconnected that joint, slapped some thick grease into the female end of the joint, then put it back together. It killed the vibration and noise. Quick fix.
Old 01-07-2004, 06:04 AM
Thanks for the info.....I'll give that a try.
Transfer Case Identification Project J10 General Discussion 2 03-26-2011 04:14 PM
1999 GMC Envoy Transfer case removal Bootsm Jimmy 0 12-05-2010 09:16 PM
89 K-5 with a tranny/transfer case problem curtisserrano 1969 - 1994 Full size 7 06-01-2010 08:14 AM
01 transfer case switch/4wd actuator/hvac controls catskill Problem Diagnosis 1 12-03-2008 08:20 PM
97 Transfer Case Noise thzguy C/K 3 05-21-2004 08:27 PM
