Old 01-05-2004, 01:58 PM
jsnowbordr47 jsnowbordr47 is offline
Locks for Rear door of 95 Suburban LT
I have a 1995 Suburban with the swing out doors in the back. My automatic locks will unlock every door except the back doors. I have to use a key.
Has anyone else had this problems?
Later,
Jeff
Old 01-06-2004, 12:30 AM
blueburbboober blueburbboober is offline
most likely its either wore out or the lead to it broke. check the wires going into the door, they are right by the catch. mine was broken when i bought my burb. good luck man
-Rob
No more burb for me!!
2005 Jeep Wrangler. Blue, 4.0L
2004 Jeep Wrangler Unlimited. Bright green, 4.0L. No mods yet on either!
Old 01-07-2004, 06:43 AM
RaiderRobert RaiderRobert is offline
Hey man, you have to clean the contacts on the spring loaded buttons on the door jambs. Sometimes they get corroded being brass. If you notice that the rear defogger doesn't work either, it's the same case. Otherwise, that's all I know. Good luck.
RaiderRobert
Old 01-08-2004, 12:14 PM
toivo toivo is offline
Re: Locks for Rear door of 95 Suburban LT
if you pull the panel off the right side door the lock mechanism is right behind it. there you can check it for power and lube it at the same time.
Old 01-08-2004, 08:23 PM
majorjc's Avatar
majorjc majorjc is offline
My dealer changed the lock actuators in my '99 suburban under warranty when they quit working like that. It was my back door and the passenger side rear door.
Rear Doors Won't Open bdzb1234 Econoline 2 05-06-2010 10:34 PM
Install power lock on rear door Carner Boy Cherokee 2 08-15-2005 04:27 AM
looking for Rear door window molding Lumina98 Lumina 1 06-30-2005 08:48 PM
99 tahoe rear door lock clicking but not locking harryc Tahoe 0 04-21-2005 08:11 PM
99 Taurus Wagon * Auto lock on rear door stuck jo'connor Taurus | Taurus Wagon 1 03-29-2004 05:37 PM
