Old 01-03-2004, 11:36 PM
ravman27 ravman27 is offline
help! warning indicator light
hope anyone can help. i have a 96 3000gt and lost the owners manual. i've been driving with a warning indicator light that looks like a "couthouse", it has bars on it. any idea what the light means?
thanks
Old 01-08-2004, 10:45 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
You have a serious issue!!!
Just kidding. Its just low winshield washer level.
Resistance Is Futile (If < 1ohm)
Old 01-08-2004, 01:59 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
its your coolant, and the picture is of the radiator
the winshield washer looks a little different(i thought it was a trans light when I first saw it)
Old 01-09-2004, 09:28 AM
Dunecomber Dunecomber is offline
get this
That light came on in my car when I had a cracked water pump so I replaced the water pump and the thermostat (just cause it was old and the car had a tendency to overheat) and the light is still on every now and then. Do you think a sensor may have gone bad or something.
-Jason
1994 Mitsubishi 3000GT
DNP Hard Intake Pipe, K&N FIPK, 97 Front Bumper, 97 Lifters, Gutted, Cat, Indiglo Gauges, Pioneer P840MP, Infity Kappa 693.5i, Infity Perfect 6.1 Component, Ground Control Adjustable Coil Overs
1999 Camaro (my little bros car... just getting started)
Panasonic HU
Old 01-09-2004, 01:01 PM
YogsVR4's Avatar
The light that looks like the US capitol building is the washer fluid level. I thought that is the one he is referring to since there isn't one that looks like (what I consider) a courthouse.
Go to http://www.cjbyron.com/3000GTspecsm.htm and look at the last picture on the page. Let us know which one of those was lit up.
Old 01-16-2004, 07:03 PM
Nesryn Nesryn is offline
Send a message via MSN to Nesryn
Its the orange light at the very bottom of the right side right? It's a coolant indicator. I had the same problem before I changed my water pump. Check your coolant level once in a while, and if it keeps going down then you got a problem. Otherwise it might just be a messed up sensor.
Help pls! Brake lights don't work :( fionathemystery How-To's and Walk-Through's 8 11-04-2010 08:21 AM
96 PA indicating lights Knox cnty resident Park Avenue 0 07-08-2010 01:03 PM
Tire Warning Indicator Light Fran D Windstar 8 06-29-2006 10:09 AM
dash warning indicator lights lazer1 Eclipse Problem Diagnosis 1 03-10-2005 09:08 PM
Installing a VTEC indicator light...help! Kinked210 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 01-20-2004 02:43 AM
