Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 09-10-2010, 11:27 AM
fionathemystery fionathemystery is offline
Help pls! Brake lights don't work :(
So I replaced the fuse and still dead. Wondering what I can check myself before I pull up to a mechanic. Thank you so much.
accord 2002 se
Old 09-10-2010, 02:01 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Help pls! Brake lights don't work :(
Did you check the bulbs?
Have you checked for power to the bulbs?
Have you checked for power to the brake switch?
Have you checked for power out of the brake switch with the pedal depressed?
Old 09-10-2010, 02:39 PM
danielsatur danielsatur is offline
I had one car were all the brake light bulbs were burnt out, when one go's the others will soon follow.
Start with a new, or a known good brake light bulb.
Old 09-10-2010, 05:47 PM
inafogg inafogg is offline
get a wiring diagram (sometimes free online)find out what wire
& start checking
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 09-10-2010, 06:23 PM
Thanks. I will check it out.
Old 09-10-2010, 06:25 PM
Nope. I just learned where the fuse box is. Trying to learn on my own so I'm lost in this car lingo. I appreciate the advice!
Old 09-11-2010, 10:32 AM
Copytech99 Copytech99 is offline
Was the fuse blown ??
As mentioned, check the operation of the switch & check for voltage at the switch & on the other terminal leading to the bulbs when pedal is pressed.
Old 09-13-2010, 12:28 PM
somick's Avatar
somick somick is offline
accord 2002 se
Why did you start with the fuse?
Try to replace a bulb for starters.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 11-04-2010, 08:21 AM
ZenRookie ZenRookie is offline
ok with brake lights theres only so many things it can be odds are its your break switch. Get low by your pedal and look up press the pedal in with your hand you should notice the pedal is actually pushing a button like switch. That is your brake switch. If you dont have a dvom(digital meter) or a test light get a pair of old christas tree lights out and cut one off and use it as your test light to see if your getting any power
Tags
accord , brake , lights
