Old 01-03-2004, 08:27 PM
foxxxy foxxxy is offline
check engine light
I had a remote car starter installed in my 97 Blazer. Now my service engine soon light comes on. When I reset the OBD by pulling the positive terminal on the battery, and then start the engine with the key, the light doesn't go on. But when I start it with the remote, the light comes on. I took it to Autozone to have them run a test it came up saying p1860 Transmission transfer case contact plate 'D' open circuit and short circuit to ground. It also said the PCM has determined that a malfunction exists in the electrical circuit for the torque converter clutch. However, the truck runs fine. All the power options work, the transmission shifts good. Does anyone have an idea as to what the problem could be? I've been racking my brain and just can't figure it out. Thanks.
Old 01-06-2004, 02:22 PM
ended up being related to the car starter not sending positive spark to the transmission resulting in a SES light, the tech crossed the wires coming from the bullcrap car starter and it works great, just be warn bullcrap starters(bullDOg) suck an so do the instruction tech support also is lacking in being there!
Old 01-06-2004, 07:37 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: check engine light
Yep, you are sure right about blowbog starters. I read some stuff on their technical sight and saw that it was all wrong. I pitty those that install it that way. YOu are lucky that you didn't install this starter on a Full size GM. Your tranny would have been toasted!
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
