Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 01-02-2004, 05:30 PM
jajimo's Avatar
jajimo jajimo is offline
Wheel Spacers? (Also: Thicker tires/rims?)
Has anyone used these before? King Motorsports has some H&R ones for sale, but I'm not sure how they look or if they're safe, etc. I'd like to make my wheels stick out JUST slightly, nothing too obnoxious. I saw a guy with like 10" rims and had his sticking almost completely out of his 93 Accord and I just thought it looked stupid as hell.
I'm thinking maybe add 15mm so it just barely sticks out?
http://www.kingmotorsports.com/produ...vehicle=Accord
If anyone has pics of what they look like on a car, it'd be great. Thanks!
I'd also like to replace my rims and tires some day, but I'm hoping for something larger than stock but not gigantic (i.e. 22"s). My car isn't lowered so hopefully I won't have clearance issues. I was thinking maybe 17x7.5s or 18x8s. Does anyone have either of these and pics of what they look like on their car? Any suggestions as to which manufacturer / model? Thanks again!
Old 01-02-2004, 08:47 PM
BullShifter's Avatar
Re: Wheel Spacers? (Also: Thicker tires/rims?)
Wheels spacers are more for race use(suspension set-up) than street(looks) use. They can put extra strain on wheel bearings causing premature failure. Just make sure NOTHING rubs during the entire suspension travel & streering lock(front)
see different wheels/sizes on your car @ www.tirerack.ccom
The larger the rim gets, the shorter the sidewall gets. Tire's sidewall is the 1st thing to absorb bumps/road surface.
Old 01-02-2004, 09:30 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Re: Re: Wheel Spacers? (Also: Thicker tires/rims?)
I'd like to add that it's not necessary if you get the right size wheel and offset with tires. Those wheel spacers are usually for show cars with wide body kits or die hard racers who are allowed to push the wheels out for better center of gravity, but it DOES put more strain on the drive train and suspension components.
I use a small 3mm spacer on the rear of my car since my 15x7" 45mm offset wheel hits the rear upper control arm. if you go this route you want to make sure you have at LEAST 7 full turns of your lugs for proper seating of your lugs.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 01-02-2004, 10:01 PM
jajimo's Avatar
Thanks for the info. The reason I inquired about the pics for the wheels/tires is that I would like to see the difference between 7.5s and 8s when you look at them from the front or rear of the car.
For those fellow 94-97 Accord owners, what do you suggest? 17"s or 18"s?
Pros/Cons of Upgrading to Larger Wheels Nav712 Tires and Wheels 1 08-15-2011 08:34 PM
Tire rim protector dents wheel rim over pothole??? laup Tires and Wheels 4 05-30-2011 08:31 AM
Tires for 15 x 10 Rims? z4teen Tires and Wheels 1 06-03-2009 08:29 AM
wheel spacer, bigger tires? chd1287 Tahoe 4 03-25-2008 06:53 PM
Thicker tire speed-d3mon Tires and Wheels 1 03-03-2002 11:25 AM
